Thread: big oil leak on front cover side of engine
Results 1 to 6 of 6
  1. #1 big oil leak on front cover side of engine
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    before i tore the top end of my engine down, i had a large oil leak that i thought was from the LIM. well engine is back together and it is still there. i had replaced the tore up oil filter housing gasket, still leaks.
    i lose about half a quart after about 60miles of driving daily.
    its on the passenger side of engine.
    where could the leak be, that leaks half a quart a day
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: big oil leak on front cover side of engine
    valve covers???
    Oil pressure switch?
    Get under there and look.
  3. #3 Re: big oil leak on front cover side of engine
    start your car turn the wheels all the way to the left, get a flash light, and look behind the pass side tire at the oil filter, (leave the car running) just past it is the oil pressure sensor. if its leaking, it leaks right where the plug, plugs into it.
  4. #4 Re: big oil leak on front cover side of engine
    Mar 2012
    Dallas
    timing cover main seal. changed, no more oil leak!
    it was not seated properly and the mating surface was all scratched up, with burrs sticking up.
  5. #5 Re: big oil leak on front cover side of engine
    Feb 2009
    NE
    How were you able to confirm it was that leaking? I have a leak, bottom of oil pan is covered so that every pan bolt has drips of oil but no obvious source. It does not look obvious that either front or rear valve covers gaskets are doing it. If kind of seems to be coming from the front of engine it seems but trying to see anything in detail is hard from under or looking down from top.
  6. #6 Re: big oil leak on front cover side of engine
    you need to de=grease your engine, top and bottom, and the trans, then watch it over the next few days, by getting under it and looking for a trail of oil.
  1. new engine cover, braces n fusebox cover
    By beckys2000gt in forum Visual/Body Modifications
    Last Post: 05-27-2010, 09:40 AM
  2. Help with Valve cover leak
    By gwizlo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2009, 09:24 AM
  3. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
  4. cam cover oil leak?
    By Golgo13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2008, 09:23 PM
