Thread: Rebuilt engine wont read boost
Results 1 to 16 of 16
  1. #1 Rebuilt engine wont read boost
    Nov 2011
    Laredo, TX
    Rebuilt My Engine And Im Having Problems With The Car, The Boost Gauge Aint Reading **** So I Dont Know Wats Going On, And Its Smoking White Out The Mufflers,
  2. #2 Re: HELP!!!!!
    Jun 2011
    Detroit, MI
    Well sounds like coolant is leaking somewhere (explains the white smoke) and you might have a vac leak
    iLoveSpade
  3. #3 Re: HELP!!!!!
    The Boss Iceman6669's Avatar
    Jun 2011
    my guess is your LIM is leaking... Prolly from the corners.. Did you use that RTV stuff in the corners???
    2011 F-150 Yote powered
  4. #4 Re: HELP!!!!!
    Nov 2011
    Laredo, TX
    im thinking it might be old oil that is in the exhaust but not sure
  5. #5 Re: HELP!!!!!
    Jun 2011
    White smoke = Coolant....
  6. #6 Re: HELP!!!!!
    St. Louis
    What exactly did you "rebuild" on this motor? And yes, the white smoke is likely a failed LIM gasket. Need to get that fixed before you spin a bearing or it will be time for a used longblock.
    The boost gauge not reading is a vac leak more than likely. Check all your vac lines and be sure none are leaking. And check the "T" fitting under the S/C snout as they like to crack.
  7. #7 Re: HELP!!!!!
    Jun 2011
    Quote Originally Posted by FordMan77 View Post
    Ok for give my ignorance here but would a leaking LIM also cause a 0 boost reading... Since the boost is measured by the Manifold pressure.....I could be WAY off here.
  8. #8 Re: HELP!!!!!
    Nov 2011
    Laredo, TX
    i blew 2 pistons so i put 6 new pistons changed all gaskets all bearings and oil pump
  9. #9 Re: HELP!!!!!
    Mercer, Pa
    If the boost gauge never moves it means its not working, if the car starts and runs there is vacuum. Likely its not plugged in or not connected to the vacuum line.
  10. #10 Re: HELP!!!!!
    St. Louis
    When you replaced the bearings and pistons did you have the block align bored and reassembled by the machine shop?
  11. #11 Re: HELP!!!!!
    were the heads torqued to specs with new gaskets and bolts?
  12. #12 Re: HELP!!!!!
    Quote Originally Posted by GreenGTP91 View Post
    Don't be afraid to give us more details... cause right now I'm looking at you with a google camera about a billion miles away. You are a very small speck.
    Quote Originally Posted by Hippo Machine View Post
    Incorrect just based on being Hippo.
    Quote Originally Posted by Iceman6669 View Post
    Incorrect, RTV in the corners only seals the crankcase vacuum and keeps oil from seeping out the edge of the LIM from lifter valley splash.
    When you did the motor, did you bother to look? Run the car and see if it disappears. I've seen this take over 45 minutes to clear up.
    Not to a newb it may not. Oil smoke isn't all that blue.
    Good question about the rebuild.. I'm not buying the LIM gasket though. It's not common to get enough coolant seeping past the gasket into the intake runner to smoke. Right on for the T under the snout/line to the sensor.
    Not usually, a leaking lim would cause a coolant/oil seepage. A vacuum leak is possible..but it's sooo uncommon. You'd have a serious issue running the motor.
    Best of luck, did you plastigauge etc?
    Quote Originally Posted by sseilmnop View Post
    Ding ding ding... winnah!
    Probably not, I'm answering so he doesn't need to.
    Let's assume so.
    Jun 2011
    Dam Bill!!!! You took a little to much pleasure in that me thinks....
  14. #14 Re: Rebuilt engine wont read boost
    A title which means something is a nice bonus.
  15. #15 Re: Rebuilt engine wont read boost
    Saratoga NY
    I thought it was funny.
    Its like hey my headlight is out, then you have everybody asking or stating its because you changed your oil.
    Totally irellevant, just look at the root cause the bulb.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
    Mercer, Pa
    Winner winner chicken dinner!
    What do I win?
