Thread: weird studder and lag
Results 1 to 5 of 5
  1. #1 weird studder and lag
    SE Level Member 99gtp3's Avatar
    Apr 2012
    mn/wi
    Hi sorry if this is dumb but I new to this car I got a 99 gtp with 159xxx its stock besides fender wall intake and sometimes on start up it chugs for like 5 senconds and also sometimes lags wen I get on it but geta past it if i.get on her more.. I bought cat from one owner old man so not beatin to sh!t... Im thinkin fuel fillter? fuel pump kinda sounds loud at idle? But I may just not be use to this one.. I was also told it had small intake leak I have yet to see lose of anti freeze and no its not going in oil thought id thro that in there if that may create this problem from mabe a vaccume leak? Any suggestions guys? Thanks mike
  2. #2 Re: weird studder and lag
    St. Louis
    Yes, check the "T" fitting under the S/C snout. They like to rot there. And of course all other vac lines. Sounds like it's time for plugs/wires/fuel filter and then go from there. Take a look at the "Safely modding your 3800" thread to get the proper brand and type of spark plugs. No Platinums or Bosch. Go w/ lifetime warranty wires. Delco's are good.
    Are you running at least 91 octane fuel in it? If not, then do so before you destroy a piston or 2.
  3. #3 Re: weird studder and lag
    ^^ That guy knows what's up. The car chugging/studdering sounds like a vacuum leak or tune up.
  4. #4 Re: weird studder and lag
    Apr 2012
    mn/wi
    I always run 91 octane.. I think it read around 12 vacuum ill have to double check.
  5. #5 Re: weird studder and lag
    you want atleast 19ish
  1. FIXED!! Engine studder, tach drop, P1361 (video added)
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 04:14 PM
  2. weird DTC...
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-17-2010, 12:33 AM
  3. weird....
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-24-2010, 12:30 AM
  4. weird that my car is doing this!!!!!
    By lilredss0287 in forum Turbo
    Last Post: 12-05-2008, 04:59 AM
  5. weird...
    Last Post: 10-15-2008, 10:56 PM
