Thread: Low coolant indicator
Results 1 to 6 of 6
  1. #1 Low coolant indicator
    SE Level Member thenose's Avatar
    Apr 2012
    Athol, Massachusetts
    Hello again,
    My 2000 GTP has a low coolant indicator lit. The coolant itself is fine and the previous owner told me he replaced the sensor to no effect. Assuming he really replaced it (I haven't had a chance to check yet), is there anything else that might have the light come on. Seems to only be the light, the car runs cool and the coolant is fine.
    Thanks
  2. #2 Re: Low coolant indicator
    Saratoga NY
    Sounds like LIM gaskets, if the fluid level is fine and stays the same, it could be coolant sludge boogering the sensor.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  3. #3 Re: Low coolant indicator
    Apr 2012
    Quote Originally Posted by gmpowered View Post
    Think a coolant flush would clear it then?
  4. #4 Re: Low coolant indicator
    Saratoga NY
    It certainly wouldn't hurt. It would be maintenance anyway.
  5. #5 Re: Low coolant indicator
    Apr 2012
    As I bought the car (obviously) used, I do not know what maintenance was actually done. I know what I was told was done, but....
    A flush would be a good idea anyway. See if I can't get it done this weekend (in my copious free time).
    Thanks all
  6. #6 Re: Low coolant indicator
    Where do LIM gaskets come into this guy?
    Check the sensor. Replace it to be sure if you want. Check the wires for loose connections, go over the basics.
    If all else fails, id unplug the sensor and forget about it.
  1. Gear Indicator Always On?
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2011, 10:40 AM
  2. Low Coolant Indicator
    By Grand Prix1 in forum General Tech Discussion
    Last Post: 10-19-2010, 03:21 PM
  3. Gear Indicator on 99 gt
    By bigboibbp in forum Audio, Security & Visual Electronics
    Last Post: 10-18-2009, 11:38 AM
  4. tcs off indicator and ABS indicator both on - why??
    By RealtyCaffeine in forum General Tech Discussion
    Last Post: 08-13-2009, 06:17 PM
  5. boost indicator on DIC
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2008, 10:17 AM
