well I guess it could be the cat. Try and restart it... The cat being clogged should let it start and then start having problems when you put a load on it. The other way to test if the cat is clogged is to unhook your upstream O2 sensor and hook a compression gauge there and see how much PSI you get as back pressure... Anything over 1 PSI is bad.
