Thread: Tools for replacing valve springs
Results 1 to 13 of 13
  1. #1 Tools for replacing valve springs
    Slower, Lower Delaware
    I'm replacing valve springs and want to know what the best tool is to use to compress the valve springs. I've done many V8s but never did an engine with one bank against the firewall.
    TIA.
  2. #2 Re: Tools for replacing valve springs
    SE Level Member tu8i1o7's Avatar
    Siuox Falls, SD
    That's the type I have always used, just be sure to use compressed air in the cylinder so you don't drop a valve into it.
  3. #3 Re: Tools for replacing valve springs
    Quote Originally Posted by tu8i1o7 View Post
    Yeah, I'll have a compressor here. I'll look for a tool like that. I assume you mean it will fit in that cramped area. Thanls.
  4. #4 Re: Tools for replacing valve springs
    Siuox Falls, SD
    Quote Originally Posted by Sudden View Post
    Yea, i have used it on my 05 with the heads installed. I didn't think the lever style worked with the heads installed on the block since it would just push the valves down.
  5. #5 Re: Tools for replacing valve springs
    Minnesota
  6. #6 Re: Tools for replacing valve springs
    Quote Originally Posted by Pure2sin View Post
    How's that thing work?
  7. #7 Re: Tools for replacing valve springs
    Minnesota
    It screws into the holes for the rockers and lets you do two valve springs are once when pressurizing the cylinder.
  8. #8 Re: Tools for replacing valve springs
    Minnesota
    Or you can just use a lever style.
  9. #9 Re: Tools for replacing valve springs
    I figured on using a lever but I didn't know what type would work for this job.
  10. #10 Re: Tools for replacing valve springs
    Minnesota
  11. #11 Re: Tools for replacing valve springs
    Thanks, I totally forgot youtube for some reason. I have that tool I just didn't think there'd be enough room to move it around like that. I used that same tool on my '66 Corvette when I put my 350 cam in.
  12. #12 Re: Tools for replacing valve springs
    Siuox Falls, SD
    nice... I thought there wouldn't be enough pressure to use those. Hopefully you don't get a stuck lock haha
  13. #13 Re: Tools for replacing valve springs
    Think I'm set. I used this one on my '66 corvette. It worked good. Looks like by the video theres enough room.
  1. Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    By zguy in forum Brakes/Suspension/Chassis
    Last Post: 04-02-2012, 10:13 PM
  2. Replacing valve cover gaskets
    By jokyfo in forum General Tech Discussion
    Last Post: 03-18-2012, 02:00 PM
  3. Valve Springs
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2011, 07:21 PM
  4. Replacing valve cover gasket
    By Haulero in forum General Tech Discussion
    Last Post: 12-17-2010, 11:29 PM
  5. valve springs
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-07-2009, 10:33 PM
