Thread: Replacing SC coupler, anything else?
Results 1 to 4 of 4
  1. #1 Replacing SC coupler, anything else?
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Its about time I replace my SC coupler for it has been making some noise for a while now. Do I only need the coupler and SC oil to do this job? Should I replace anything else while It is going to be taken apart. I kind of want to get my inlet on the blower ported and my TB. What your opinion on the porting? I believe I have read somewhere, with a ported TB it will help with the loud sucking noise come from my intake. I dont like that noise at all.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  2. #2 Re: Replacing SC coupler, anything else?
    Dont port the TB unless you can custom maf tune.
    Make the Triangle bigger for the blower.
    You'll need anerobic sealer for the snout the blower case, thin bead all the way around and bolt together.
  3. #3 Re: Replacing SC coupler, anything else?
    Alaska
    I have the outlet ported from my LIM gasket change. And that anerobic sealer as well. Thats some expensive stuff for how much I use it lol.
  4. #4 Re: Replacing SC coupler, anything else?
    Alaska
    Any ZZP codes I can use for a discount? : )
  1. S/C Coupler not right??
    By 98GTPCALGARY in forum General Tech Discussion
    Last Post: 07-25-2012, 11:45 PM
  2. SC Coupler
    By JB381 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2010, 07:15 PM
  3. Replacing SC coupler sealing question?
    By PCweber in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2009, 04:40 PM
  4. Which coupler?
    By karkrazy1971 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 02:40 PM
