Thread: car is running low boost and is throwing a p1646
Results 1 to 3 of 3
  1. #1 car is running low boost and is throwing a p1646
    SE Level Member sseigtp's Avatar
    Milwaukee, Wisconsin
    I have a 98 gtp has slp headers and exhaust, genV sc, fw cai. it is only running between 2-3psi for boost (checked it with my scan gauge) its also throwing a code p1646.
    i checked all the vacuum lines and they all look good.
    Mercer, Pa
    Sounds like boost bypass valve or the solenoid m. Both mine have gone bad but I've got high miles. Boost bypass had hole in diaphragm, found it with a hand vacuum pump.
  3. #3 Re: car is running low boost and is throwing a p1646
    Troy OH
    P1646 is a boost control code. like he said, either bad solenoid or bad valve. it'll limit the cars boost because, well... it can't put it under boost. so that's to be expected.
  1. 1997 GTP running poorly in boost
    By sswisley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2012, 02:54 PM
  2. Throwing all my GTP parts into the trash
    By BobC in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 08-13-2011, 06:42 AM
  3. Throwing codes
    By batman1988 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2011, 03:37 PM
  4. How many pounds of boost should I be running?
    By slow94formula in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 01:36 PM
