Thread: AFTER GEN V SWAP!!! Help
Results 1 to 11 of 11
  1. #1 AFTER GEN V SWAP!!! Help
    Mar 2012
    Hays, KS
    Guys i have a constant misfire cyl 1 and 5 not as often with loud backfire out exhaust. What should i check? Did not have misfires before swap. My friend did the work who is a GM Master Certified tech so i trust his work lol
  2. #2 Re: AFTER GEN V SWAP!!! Help
    Step one: Question work and search for vac leaks, misplaced plug wires, properly connected plug wires etc.
  3. #3 Re: AFTER GEN V SWAP!!! Help
    Mar 2012
    Hays, KS
    What is the firing order? 99 gtp
  4. #4 Re: AFTER GEN V SWAP!!! Help
    Won't do you any good though.
    coils are 6/3, 5/2, 1/4.
    Doesnt matter which one goes top or bottom as long as its on the right coil.
  5. #5 Re: AFTER GEN V SWAP!!! Help
    Mar 2012
    Hays, KS
    What do u mean "won't do me any good?" Lol
  6. #6 Re: AFTER GEN V SWAP!!! Help
    The firing order doesnt help.
    Connect correct wires to correct cylinders and coils then you win.
  7. #7 Re: AFTER GEN V SWAP!!! Help
    Mar 2012
    Hays, KS
    What is the cylinder order?
  8. #8 Re: AFTER GEN V SWAP!!! Help
    like this.
  9. #9 Re: AFTER GEN V SWAP!!! Help
    front bank from passenger to drivers side: 1 3 5.
    rear bank from passenger to drivers side: 2 4 6.
  10. #10 Re: AFTER GEN V SWAP!!! Help
    Mar 2012
    Hays, KS
    Thanks for the help!
    Canton, Ohio
    Check to see if the wires are arching on the s/c casing... Had that occurrence on dthreaps car
    Swiftly sent using my GNex
  1. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  2. gen 5 swap
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2011, 10:11 PM
  3. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
