Thread: 3800 sc swap into 95 gtp
Results 1 to 12 of 12
  1. #1 3800 sc swap into 95 gtp
    SE Level Member greenmachinegtp's Avatar
    Crossville, TN
    Can I run this engine off of my stock computer and harness. Dropped a valve in my lq1. Cant find another motor. Plenty of 3800s around. Will series 2 work? Series 1?
  2. #2 Re: 3800 sc swap into 95 gtp
    Would be all custom.
    Engine/trans, wire harness, the whole shebang.
    Cant just do a straight drop in.
  3. #3 Re: 3800 sc swap into 95 gtp
    new britain, ct
    no it wouldnt.
    go find a gen 1.5 lumina that came with a 3800. (95-99)
    it has all the parts you need.
    no custom parts needed.
    take the engine/tranny mounts out, axles...although the wiring will indeed be a beotch, it can be done.
    07 Black GXP.
  4. #4 Re: 3800 sc swap into 95 gtp
    Crossville, TN
    Why? Trans bolts up. I have no emissions test. I dont need a band wagon opinion. I need to know if it will run. I dont need or want an upgraded trans. I just want the engine to move the car. Gotta have a way around. Ill upgrade everything else later. Will it run?
  5. #5 Re: 3800 sc swap into 95 gtp
    Crossville, TN
    Quote Originally Posted by ctracer View Post
    no it wouldnt.
    Thanks ctracer
  6. #6 Re: 3800 sc swap into 95 gtp
    new britain, ct
    youll have to tune the car for the different gear ratios for the 4t60 trans if you arent using a 4t65. forgot to put that in there.
    07 Black GXP.
  7. #7 Re: 3800 sc swap into 95 gtp
    Crossville, TN
    Why if I use my computer and harness and trans, and all I want is to change the motor. Can this stock pcm and harness run a stock 3800? All thT needs to plug in is the ckp, tps, I can swap the ect and injector clips and what not. Wont this work? Will I have to even do that much?
  8. #8 Re: 3800 sc swap into 95 gtp
    Crossville, TN
    I spliced and obd1 ecm into a obd2 prelude once. It ran good. Is there any reason ill absolutely have to do anything besides wiring to make the engine run?
  9. #9 Re: 3800 sc swap into 95 gtp
    new britain, ct
    Quote Originally Posted by greenmachinegtp View Post
    i dont see why you would have to do anything else except change the harness or even modify it to make the engine run. if i think of any reason ill put it here ASAP.
    07 Black GXP.
  10. #10 Re: 3800 sc swap into 95 gtp
    Cambridge, Ontario Canada
    Good luck will be cool when done
    2005 E55 - stock
  11. #11 Re: 3800 sc swap into 95 gtp
    Crossville, TN
    Thanks. I actually found an lq1 with 88000 miles today for 450, but its between, that or the 3800 sc for 160. I bought it because of the lq1, but idk. Depends on how much I can get how fast. I gotta get this thing going. Tired of being stranded.
  12. #12 Re: 3800 sc swap into 95 gtp
    new britain, ct
    honestly if you dont plan on getting a 4t65 than your tranny IS going to go out with a sc 3800...so youll be stranded anyways.
    go with the lq1 if you dont want to swap trannys.
    07 Black GXP.
  1. need help with a 3800 swap
    By yeazel1690 in forum General Tech Discussion
    Last Post: 01-05-2012, 05:04 PM
  2. 3800 series II rwd swap
    By ibhuff in forum General Tech Discussion
    Last Post: 11-20-2011, 11:39 AM
  3. Top swap 3800 SE
    By Austin2000SE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2011, 09:51 PM
  4. 3800 Series 2 swap
    By Condor120 in forum General Tech Discussion
    Last Post: 04-25-2010, 05:18 PM
