Thread: GenV Supercharger Pulley removal
Results 1 to 8 of 8
97gtpjoe GenV Supercharger Pulley... 04-01-2012, 11:31 AM
matt5112 Re: GenV Supercharger Pulley... 04-01-2012, 11:37 AM
97gtpjoe Re: GenV Supercharger Pulley... 04-01-2012, 11:45 AM
TheOtherNick Re: GenV Supercharger Pulley... 04-01-2012, 11:48 AM
97gtpjoe Re: GenV Supercharger Pulley... 04-01-2012, 12:47 PM
gloebird Re: GenV Supercharger Pulley... 04-01-2012, 01:36 PM
97gtpjoe Re: GenV Supercharger Pulley... 04-01-2012, 01:52 PM
Swiggles Brake the flat part of the... 04-01-2012, 04:17 PM
  1. #1 GenV Supercharger Pulley removal
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Im trying to install an mps by smoothflow on my GenV supercharger , th instructions say to remove bolt from pulley and then use the pulley puller(purchased) only problem im having is that there is no bolt where I could put my wrench into any help will be appreciated thanks.
  2. #2 Re: GenV Supercharger Pulley removal
    should be a plastic "christmas tree" esque fastener then.
  3. #3 Re: GenV Supercharger Pulley removal
    Jan 2009
    Ok so how do I remove the fastener?
  4. #4 Re: GenV Supercharger Pulley removal
    Charles City, IA
    screw driver, or the special body tool.
    SMGPFC Two Nipple General
  5. #5 Re: GenV Supercharger Pulley removal
    Jan 2009
    the pulley is the one on top not the bottom one .
  6. #6 Re: GenV Supercharger Pulley removal
    Dec 2011
    Orlando, FL
    yes, and a quick tip: that plastic piece will unscrew counter-clockwise. i wasted so much time trying to rip it out like a caveman. just unscrew it. then follow the instructions with the puller kit and its generally a piece of cake. make sure you put that modular piece on correctly, you only get one shot at it.
  7. #7 Re: GenV Supercharger Pulley removal
    Jan 2009
    Quote Originally Posted by gloebird View Post
    Thanks gloebird! ill use some penetrating spray to soak the plastic piece its super tight.
    Quincy, Mass
    Brake the flat part of the plastic and then use some needle nose pliers to unscrew the plastic plug. Go get a new pack of those plastic retainers (the plug) at a parts store and put one in.
    No more GP 04 Impala SS Indy:
  1. The Eaton Gen V supercharger faq / swap thread!! (genv, gen five, gen 5)
    By copgtp in forum How To Write-Ups/Tech Tips
    Last Post: 08-17-2017, 10:27 AM
  2. Tensioner pulley removal
    By srspicer in forum General Tech Discussion
    Last Post: 05-08-2011, 03:36 PM
