Thread: Aeroforce Scan Gauge
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Aeroforce Scan Gauge
    Donating Users blowfishRus6's Avatar
    g.a.
    has anyone had any play time with this..
    MSD DashHawk Vehicle Information Display - PFYC
    can the aeroforce do a cylender misfire cycle?? would that be a pretty handy feature to have?? with out a tunner there is not much i could do about it tho.
    just wondering what yall thought about it
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #22 Re: Aeroforce Scan Gauge
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by blowfishRus6 View Post
    It will display total misfires. You can go to Interceptor OBD2 data stream gauge and scan tool by Aeroforce Technology and download the manual. It lists the available options.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #23 Re: Aeroforce Scan Gauge
    Barksdale AFB, LA
    The Aeroforce can list your misfires by individual cylinders all at the same time.
    2009 Subaru Impreza WRX STI
  4. #24 Re: Aeroforce Scan Gauge
    g.a.
    okay thats cool. i was just wondering if that other guage was any better. not by the looks of it tho
    its slow.
  5. #25 Re: Aeroforce Scan Gauge
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    Quote Originally Posted by jacobmh27 View Post
    this is what I am planning on doing as well. I ordered a boost gauge and Oil Pressure from Prosport I can not wait to get them in I ordered the Pillar 3 Gauge pod too. I am not sure what gauges I want to put in to the spot that you have your AF and Trans temp I was thinking Transtemp and Something eles. What is good about monitoring your AF
    its the same idea as other gauges...to watch whats going on in the engine as well as to monitor if anything goes wrong...hope that helps
  6. #26 Re: Aeroforce Scan Gauge
    St Louis MO
    Quote Originally Posted by Sabrewings View Post
    How does it fit all 6 cylinders on that little display at the same time?
    I can't see misfires anyway since my P0300 has been disabled, but just in case I need to re-enable, how do you do this?
    2010 Camaro SS LS3
  7. #27 Re: Aeroforce Scan Gauge
    Barksdale AFB, LA
    Quote Originally Posted by IndeedSS View Post
    It lists them like this...
    Cylinder #1: 0
    Cylinder #2: 0
    Cylinder #3: 0
    Cylinder #4: 0
    Cylinder #5: 0
    Cylinder #6: 0
    And I think the last couple lines are all "X" because it's also available for V8s. It can fit it all just fine...
  8. #28 Re: Aeroforce Scan Gauge
    Dec 2012
    Canada
    I am going to be adding an Aeroforce Gauge to my 02 GTP, can I get the power required through the cigarette lighter by the way of a plug?
  1. Aeroforce scan gauge performance mode
    By spidamanSS in forum General Tech Discussion
    Last Post: 07-02-2008, 02:25 PM
  2. Aeroforce gauge...
    By duane9586 in forum General Tech Discussion
    Last Post: 07-01-2008, 01:32 PM
