Thread: ZZP stage II I/C install
Results 1 to 8 of 8
  1. #1 ZZP stage II I/C install
    Nov 2011
    Bayamon, Puerto Rico, Puerto Rico
    Im going to install the I/C tomorow.
    Did modified gaskets. Now, any suggestions installing them?
    This will be my first time and I want to do it right!
    Any pics???
  2. #2 Re: ZZP stage II I/C install
    take your time and make sure you seal everything correctly the first time. plumb the lines nicely so they dont rub, ANYWHERE.
    Don't use gaskets. Use rtv.
  4. #4 Re: ZZP stage II I/C install
    Don't use ZZP gaskets... they are named Garleaks for a reason. Get a couple rolls of gasket material and make your own if you are going to do it. I like Permatex 26B on both sides of it. Never had a leak yet.
  5. #5 Re: ZZP stage II I/C install
    Nov 2011
    Well, my first install. At least everything aling and went good. I used modified stock gaskets with little rtv. But surrounded all the areas completely, hope when.i fire it up doesnt leak! If it does. Ill use rtv only, btw where can I find these rolls you talk about?
  6. #6 Re: ZZP stage II I/C install
    Minnesota
    I just picked up a couple rols at advanced auto. I got the rubber ones. They also have cork and paper, but I believe rubber it the best for this.
    Also Bill I couldnt find permatex 26b anywhere? would the grey permatex work?
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  7. #7 Re: ZZP stage II I/C install
    its just high temp red RTV.
  8. #8 Re: ZZP stage II I/C install
    Minnesota
    Oh ok thanks! and the rubber gasket material is the right stuff?
  1. Devilsown Stage 2 Progressive Alcohol Injection Install...
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 03-29-2015, 04:23 PM
  2. FMHE stage 4 install.
    By TDCRacing in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2014, 10:44 PM
  3. ZZP Stage 2 Intercooler Install help
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 07:10 AM
  4. How to install stage three intercooler?????
    By GINOSGTP in forum General Tech Discussion
    Last Post: 02-25-2009, 07:52 PM
