Thread: Car Still Running Rough *FIXED*
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #21 Re: Car Bogging Down Running Rough, Randomly
    Nov 2008
    Waterloo, Iowa
    No misfires.
    Long-Term FT: Hit as low as -14.1 while driving, don't think it ever got above +8.
    Timing: 25* idling in drive, 32-36* at low speed, low-rpm, 17-18* at WOT.
  2. #22 Re: Car Bogging Down Running Rough, Randomly
    Not sure then...ever replaced the following?
    Fuel Filter?
    PCV?
    Spark Plugs?
    Plug Wires?
    ICM?
    Coils?
    Vac lines?
    Checked the Rubber "T" fittings around the top end?
    Cleaned the IAC/TPS/MAF?
  3. #23 Re: Car Bogging Down Running Rough, Randomly
    Nov 2008
    Waterloo, Iowa
    None of the above. Only thing I have done is ran with the MAF unplugged and that seems to have done nothing.
    Probably about time to do most all that though, 70k motor, I've had it for maybe 10-15k miles so i've gotta be right around 85k on it...
  4. #24 Re: Car Bogging Down Running Rough, Randomly
    It probably just needs a tune up then brutha.
    When you change the plugs/wires/FF/PCV...sand down the coil terminals a little bit to clean them...and then remove the ICM and have it tested at your local auto parts store to make sure it is in good working order. I'd also unplug the battery when you do that...because I've grounded mine out and it was a nice 150 dollar fix for stupidity.
  5. #25 Re: Car Bogging Down Running Rough, Randomly
    Nov 2008
    Waterloo, Iowa
    Any recommendations for parts? Particularly plugs? I'd just go with 104s but I still have a stock pulley and no headers.
    And what should I clean the sensors with?
  6. #26 Re: Car Bogging Down Running Rough, Randomly
    Lifetime warranty plug wires...from your local auto parts store.
    Autolite 605's...gap them at .050"
    Whatever fuel filters/PCV valves they have there...
    Testing the ICM is free...
  7. #27 Re: Car Bogging Down Running Rough, Randomly
    Nov 2008
    Waterloo, Iowa
    Advance won't test ICM. At least, not the one I usually go to. I'll have to call around.
  8. #28 Re: Car Bogging Down Running Rough, Randomly
    Could just need cleaned too.
    I've seen plenty that are just full of dirt and grime.
    When you remove the coils (5.5mm bolts btw...tiny bastards...just a clean towel to wipe it off and the bottom of the coils. Like I said before...clean the coil terminals as well.
  9. #29 Re: Car Bogging Down Running Rough, Randomly
    Nov 2008
    Waterloo, Iowa
    Will do. And O'Reilly's does ICM testing, whew. I'll have to wait a bit before doing anything, don't have another car to drive atm...
  10. #30 Re: Car Bogging Down Running Rough, Randomly
    I know it has been over the weekend...any updates broham?
  11. #31 Re: Car Bogging Down Running Rough, Randomly
    Nov 2008
    Waterloo, Iowa
    Been working mostly.
    Haven't really changed anything. It did it again once yesterday.
    Also yesterday: unplugged battery temporarily, when attempting to plug it back, it was sparking heavily and once connected, the relays would click, then power down, then click, then power down, until i unplugged it again, and during all this, when started would just die. I left it off, made a couple calls, plugged it in for ****s in giggles. No heavy sparking, no relay clicking, started normally, ran normally.
  12. #32 Re: Car Bogging Down Running Rough, Randomly
    Nov 2008
    Waterloo, Iowa
    All this has led to me thinking my problem is something electrical. The biggest change I made when I slapped on the new alternator, was I left off a ground strap I had put on a few months prior. Makes me wonder if I have any faulty or weakening engine grounds.
  13. #33 Re: Car Still Running Rough 3-28-12
    Nov 2008
    Waterloo, Iowa
    Going to start keeping the scanner plugged in and recording data, also considered the possibility of the ignition switch or even the alternator. Symptoms aren't an exact match, but it can't hurt to investigate.
  14. #34 Re: Car Still Running Rough 3-28-12
    A long shot here, but check you PCM plug in's.
    Today at school we were working on a riviera and the connectors in the back of the pcm were coming loose and casuing tons of problems. I smacked the glovebox (where the pcm is) and the car almost died, smacked it again, car died. Cleaned the connectors and plug it back in and tighten it all down and runs great. Might be worth a look.
  15. #35 Re: Car Still Running Rough 3-28-12
    Nov 2008
    Waterloo, Iowa
    Considering the PCM controls a lot of essential function (such as A/F, relays, idle, etc) and considering my problem is related to what seems to be electrical in some way, controlling the engine... it may very well be. I'll take a look and report back. Thanks!
  16. #36 Re: Car Still Running Rough 3-28-12
    Nov 2008
    Waterloo, Iowa
    Okay, so, still having troubles. To sum up what I know so far:
    - Once in awhile, the car will act like it's being choked for fuel, acceleration will be rough, as well as idling, with the potential to stall at idle.
    - Sometimes feels very lacking on power, and shifts hard
    - Rarely will drop to idle when stepping on the brake, rather than down to 12-1400 or so
    - Frequently idles slightly rough (just a bit, not nearly like when it's choking hard)
    What I did:
    - The day before this started, I replaced the alternator
    - 2 days ago, I put the old one back on, problem continued, and as of today, the old alternator stopped charging, whether it's related, or the alternator suddenly died, I haven't a clue
  17. #37 Re: Car Still Running Rough 4-5-12
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    fule pump on its way out the door, pressure regulator, failing o2, egr....my o2 seemed fine but every once in a while would spike either way irratically till i noticed my wideband and narrowband were always opposite reading of each other. replaced o2 which seemed fine and no more issue
  18. #38 Re: Car Still Running Rough 4-5-12
    Nov 2008
    Waterloo, Iowa
    I've seriously considered the pressure regulator. Suddenly choking for fuel, and at random, isn't normal.
  19. #39 Re: Car Still Running Rough *FIXED*
    Nov 2008
    Waterloo, Iowa
    Figured I should update this and say it was the ICM. I replaced that with a used one and my problems were solved. Even survived a 4-hour trip to Nebraska, and the trip back as well.
  1. 05 GTP running rough (sometimes)
    By gwog in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2012, 02:01 PM
  2. GTP running rough when hot
    By reem98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 10:09 AM
  3. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  4. 01 GTP running rough
    By tazgtp in forum General Tech Discussion
    Last Post: 03-28-2010, 04:10 PM
  5. GTP Running rough.. PLEASE HELP!!!
    Last Post: 07-11-2009, 08:46 PM
