Thread: LS1 or N* Throttle Body
Results 1 to 20 of 30
  1. #1 LS1 or N* Throttle Body
    SE Level Member 2000GTP2708's Avatar
    Oct 2008
    Missouri
    What all do i need besides the TB and is it a hard install?
    Thanks
  2. #2 Re: LS1 or N* Throttle Body
    May 2008
    staten island,NY
    check the classifieds, i found my N* on CGP brand new for 200$ complete. but to answer your question, you will need the
    throttle body
    LQ4 maf
    adapter plate for your blower ie. Gen3,Gen5
    linkage bracket
    silicone couplers
    good luck!
  3. #3 Re: LS1 or N* Throttle Body
    TDCRacing
    Guest
    Well it wasent one of you're choices and is a little higher in price but i have the 78mm TB from ZZP.
    It's the biggest,Best fitting one out there. And if you're not outflowing you're stock MAF yet then you wont need to buy a LQ4 MAF with the ZZP MAF as you're stock one will bolt right up as well as everything else like cables ect. It is the only part I can think of besides the poly mounts that i have not considered changing. And that's a good thing.
    Either way you're going to need to tune.
  4. #4 Re: LS1 or N* Throttle Body
    Barksdale AFB, LA
    What I don't like about N* throttle bodies is no cruise (I use cruise on long trips home). Anyone worked that out, or is it not an issue with LS1?
    2009 Subaru Impreza WRX STI
  5. #5 Re: LS1 or N* Throttle Body
    May 2008
    staten island,NY
    no cruise is LS1, i have cruise on my N*
  6. #6 Re: LS1 or N* Throttle Body
    Barksdale AFB, LA
    No, I know there are N* setups out there with no cruise too. I guess it all depends on who makes the parts...
  7. #7 Re: LS1 or N* Throttle Body
    Banned
    Wichita Falls, Texas
    Why would a N* or a LS1 set-up have no cruise?
  8. #8 Re: LS1 or N* Throttle Body
    Barksdale AFB, LA
    The few I've seen in person the "peg" for the cruise cable to latch on to was in the wrong spot, the wrong size, or not there at all.
  9. #9 Re: LS1 or N* Throttle Body
    Banned
    Then somebody needs to purchase the correct throttle body for the setup next time then. I have cruise control on my N* setup, I even had cruise control on my wrong year model N* setup. One of the cars around here has a LS1 set-up as well with cruise control. Neither of them should be without it.
  10. #10 Re: LS1 or N* Throttle Body
    Barksdale AFB, LA
    Quote Originally Posted by Street Wolf View Post
    See, that answers my question that there are different setups available and not all are like that. Thanks.
  11. #11 Re: LS1 or N* Throttle Body
    TDCRacing
    Guest
    lol
  12. #12 Re: LS1 or N* Throttle Body
    Oct 2008
    Missouri
    Well do you guys think i even nned one my setup is Wizaired CAI with the k&n, 3.4 pulley, 3 in catted downpipe, full 3in exhaust from zzp, p-log, 180% t-stat, and a dhp 1.0 pcm m the reason i ask is because sometimes when i let off the gas when im going around 30 mph the rpm's will drop down to about 1000 Rpm's then drop down to 500-600 rpm's like its gonna die and then shoot back up to 1000 sometimes it will do this a couple times untill i hit the gas then its fine anyone ever heard of anything like this? and also it done this before the pcm so its not the tune
    Thanks
  13. #13 Re: LS1 or N* Throttle Body
  14. #14 Re: LS1 or N* Throttle Body
    Oct 2008
    Missouri
    Ok thanks i didnt really think i did but have u ever heard of anything like what i was saying?
  15. #15 Re: LS1 or N* Throttle Body
    Barksdale AFB, LA
    Quote Originally Posted by 2000GTP2708 View Post
    Dirty idle air control valve.
  16. #16 Re: LS1 or N* Throttle Body
    Quote Originally Posted by Sabrewings View Post
    that's what i was going to say.
  17. #17 Re: LS1 or N* Throttle Body
    Oct 2008
    Missouri
    Ok thanks man ill check it out in the morning thats kind what i was thinkin too either that or the MAF sensor
  18. #18 Re: LS1 or N* Throttle Body
    Nov 2008
    Valdosta, ga
    i have cruise on my ls1 t/b
  19. #19 Re: LS1 or N* Throttle Body
    Nov 2008
    Heaven, compared to HERE
    YUP...I am the "car around here" with the LS1 setup and I definitely have Cruise!...if I get a chance later I will grab a picture of the TB and post it up here.
    personally I think the Northstar setup is an easier install but it wasn't available when I purchased mine.
  20. #20 Re: LS1 or N* Throttle Body
    Nov 2008
    Valdosta, ga
    lol man i was on a a parks hunt for a while lol but i modified the hell out of mine
  1. Throttle body gasket?
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2008, 10:46 PM
  2. Stock Throttle Body O.D.?
    By IndeedSS in forum General Tech Discussion
    Last Post: 09-03-2008, 04:26 PM
  3. Throttle Body Spacer
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 06:21 PM
  4. Throttle Body swap
    By Berger in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-23-2008, 08:35 PM
  5. HV throttle body for the L36
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:34 AM
