Thread: Where can i pick up the cheapest long block?
Results 1 to 19 of 19
  1. #1 Where can i pick up the cheapest long block?
    Jacksonville, Fl
    so recently my motor has seized and i have not pulled it quite yet but i will be within the next couple days. im 95% sure its a spun bearing. i have invested waaay too much between the suspension, a/c, and steering in hope that this newly rebuilt motor would last. i had done some modding. nothing too crazy. bored .030 over, cam, little head work. but i think im just going to go back to stock. so my question is... where can i pick up a professionally built STOCK long block for cheap? at rock auto i can pick one up for about 2500. it also has a pretty good warranty. is there anywhere else i could look that you guys would reccomend?
  2. #2 Re: Where can i pick up the cheapest long block?
    St. Louis
    Maybe Jasper. Or find a good used motor and swap that in. Morad would be a good source for one.
  3. #3 Re: Where can i pick up the cheapest long block?
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    a few years back i got an L32 complete engine with 34k on it for $600 off of car-parts.com
    in ZZP's used section they have 2 L32s for sale, one with 30k for 1400.
  4. #4 Re: Where can i pick up the cheapest long block?
    Jacksonville, Fl
    theres a l67 in my bay right now. what would it take to be able to drop a l32 in?
    Ohio
    Nothing. Straight swap. TB adapter
  6. #6 Re: Where can i pick up the cheapest long block?
    Jacksonville, Fl
    where could i pick up the adapter?
  7. #7 Re: Where can i pick up the cheapest long block?
    i have a part out up here in jersey, its a 2001 regal GS with a l67, 80,000, guy wants a grand for it.
  8. #8 Re: Where can i pick up the cheapest long block?
    Jacksonville, Fl
    nevermind i found the adapter.
    thanks scotty but the mileage is a little high for me. im probably juts gonna go with a l32
  9. #9 Re: Where can i pick up the cheapest long block?
    Quincy, Mass
    its a little more than a straight swap, but not much more. i also have a genV to l67 TB adapter for sale. pm if interested
    ClubGP Message Forum troubleshooting
    also look at the genV swap in the how to section, that is basically what you are doing.
    No more GP 04 Impala SS Indy:
  10. #10 Re: Where can i pick up the cheapest long block?
    Topeka, KS
    Just looked on Car-Part.com--Used Auto Parts Market All of them are fetching 1300 or more full motor and SC.
    Jan 2009
    Tallahassee, FL
    I've seen motors on car-part.com for as cheap as $150 with 200k+ on them, I picked mine up for $950 with 25k on it off car-parts.com. if you look there are good deals.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  12. #12 Re: Where can i pick up the cheapest long block?
    Quincy, Mass
    L26 goes for around $300 near me. if you find one from an 06+ they will have the l32 rods. then you are just doing a top swap.
    Jan 2009
    Tallahassee, FL
    Mine also came with a 6 month warranty
    77 Morris Garage B
  14. #14 Re: Where can i pick up the cheapest long block?
    Jacksonville, Fl
    but i do have a question... is the gen III s/c compatible with the l32 motor? i know it is not as efficient but i want to keep any spare parts from my old motor that i can use later.
  15. #15 Re: Where can i pick up the cheapest long block?
    Jacksonville, Fl
    i think i found a winner. on car-part.com. 55K miles $1400 69 miles away from me in lake city. already called the guy. got arrangements to pick it up in about a week and a half
  16. #16 Re: Where can i pick up the cheapest long block?
    you just have to get a throttle body adapter to put your throttle body on it from your car.
  17. #17 Re: Where can i pick up the cheapest long block?
    Jacksonville, Fl
    so the gen III will go onto the l32 intake manifold no problem?
  18. #18 Re: Where can i pick up the cheapest long block?
    i'd use the l67 lower manifold and all that goes with it. it should bolt up, people put the gen V l32 manifold and blower on l67 all the time.
    *EDIT: but if you are getting a complete engine, sell the the blower and heads and all the pulleys off your old engine for a complete top swap, it will get snatched up and you can recoup some of your losses.
  19. #19 Re: Where can i pick up the cheapest long block?
    Jacksonville, Fl
    ya thats the plan. i got an xp cam, push rods, lifters, 105 springs and machined/modded heads im going to sell off if everything goes well.
  1. cheapest turbo?
    By pixel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2011, 05:48 PM
  2. Cheapest scanner
    By ckrummy in forum General Tech Discussion
    Last Post: 08-08-2010, 03:41 PM
