Thread: GTP Wont start first time, Stutters when punched.
Results 1 to 9 of 9
  1. #1 GTP Wont start first time, Stutters when punched.
    SE Level Member azmattaz06's Avatar
    Feb 2009
    Tucson
    So my GTP takes two times or even more before it'll start, Fuel pressure issue im guessing but also i realized when i tried to punch it that it stutters a lot too, Could this be a Fuel Pump orrrr?? Where should i start?
  2. #2 Re: GTP Wont start first time, Stutters when punched.
    Portland Oregon
    Could be fuel pump, fuel filter, or fuel pressure regulator. Pull the vacuum line off the pressure regulator and smell it. If it smells like gas you probably need a new one. Also if you haven't changed your fuel filter in a long enough time to not remember, it's time to do that too. They're cheap.
  3. #3 Re: GTP Wont start first time, Stutters when punched.
    Change filter, check pressure. If you think you have fuel issues, those are your two best places to start.
  4. #4 Re: GTP Wont start first time, Stutters when punched.
    Feb 2009
    Tucson
    Don't have the tool to check pressure, But i pushed down the little nozzle type thing on the fuel rail to check the pressure and no fuel at all came out, So the pressure leaks out pretty fast and when i go to start the car it has to build it up, but when the car is running it runs ok unless i punch it.. what do you guys think? i was told by someone it wouldnt be the pressure regulator.. u guys tell me
  5. #5 Re: GTP Wont start first time, Stutters when punched.
    SE Level Member Elrodd384's Avatar
    Mar 2012
    Fort Campbell, KY
    My Crank Position Sensor just went out on my and cause some funky issues. It's basically what tells your PCM where to set your timing. might look into that as well. 15 bucks on rockautoparts.com
  6. #6 Re: GTP Wont start first time, Stutters when punched.
    Feb 2009
    Tucson
    *Bump* I dont think the Crack sensor would cause the fuel lines to loose pressure, Thanks though.
  7. #7 Re: GTP Wont start first time, Stutters when punched.
    Feb 2009
    Tucson
    Ok so i changed the Fuel pressure regulator and still doing the same thing, what next? fuel pump?
  8. #8 Re: GTP Wont start first time, Stutters when punched.
    Portland Oregon
    Fuel pump is next. Only other thing in the system that is responsible or fuel pressure. Pretty sure you can rent a fuel pressure gauge at autozone or oreilly's
  9. #9 Re: GTP Wont start first time, Stutters when punched.
    if you can find the part # for just the pump, not the whole sending unit, they cost under 50 vs the whole pump unit as a whole.
    is a easy swap too.
  1. GTP Wont start first time, Always on the second, But runs great.. ?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2012, 07:37 PM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. car wont start
    By mezzoni in forum General Tech Discussion
    Last Post: 08-30-2010, 08:19 AM
  4. 93 with 3.1 wont start!
    By rvdavis in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-02-2009, 05:27 PM
  5. >??? dam still wont start
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-12-2008, 09:58 PM
