Thread: Replacement lifters? Texas Speed?
Results 1 to 15 of 15
  1. #1 Replacement lifters? Texas Speed?
    GTX Level Member crbquist's Avatar
    Massachusetts
    I'm looking to buy a set of factory GM replacement lifters and heard they can be purchased at Texas Speed. The problem is, I can't locate any lifters for the L67 or L32 engine on their website. There is an option for "GM" replacement lifters, but how do I know these are the correct ones? There are also LS7 lifters that sell for $38.99 a pop!
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #2 Re: Replacement lifters? Texas Speed?
    us
    contact them?
  3. #3 Re: Replacement lifters? Texas Speed?
    Minnesota
    I wouldn't waste your time buying NEW lifters. If you need a set post a wanted thread on here and someone will probably have a set for you.
    Buy the 16 pack of ls7 lifters.
    Pure, those sure are some nice lifters.
  5. #5 Re: Replacement lifters? Texas Speed?
    GT Level Member ls1camino's Avatar
    Laurel, MD
    This.
    Speedinc.com also offers free shipping on purchases over $100.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  6. #6 Re: Replacement lifters? Texas Speed?
    Texas Speed is where I always bought my lifters.
    Also, since I don't care to send ZZP my money...I've had GREAT experiences with Texas Speed.
  7. #7 Re: Replacement lifters? Texas Speed?
    Pennsylvania
    28-12499225-12 - $97.99
  8. #8 Re: Replacement lifters? Texas Speed?
    Quincy, Mass
    i have a set of stock lifters i can send you, i forget the miles on them but they were working fine when i removed them. also have a set comp cam OE lifters if your interested. send me a pm.
    also from what ive read the ls7 are stock replacements that are made to handle higher rpms. they are the now the replacement part number for our lifters.
    No more GP 04 Impala SS Indy:
  9. #9 Re: Replacement lifters? Texas Speed?
    Everything GM has made from like 93 or 94 to current all uses the same lifter...something I liked, its all the same junk.
  10. #10 Re: Replacement lifters? Texas Speed?
    Massachusetts
    I don't necessarily need them, I just figured it would be a good idea to replace my 105k mile stockers since the motor will be torn down for a cam swap soon enough.
  11. #11 Re: Replacement lifters? Texas Speed?
    It wouldn't HURT, but it also isn't really necessary.
  12. #12 Re: Replacement lifters? Texas Speed?
    Pennsylvania
    It's a hundred bucks to never see that part again. If it helps you sleep easy, might as well.
  13. #13 Re: Replacement lifters? Texas Speed?
    Massachusetts
    There are the "GM replacement lifters" for $97.99, and also the "GM replacement LS7 lifters" for $139.99, so which ones should I get? I have heard to go with the LS7, but then again why not just the standard GM? Also, how do I know if there are 16 in a set, because it does not specify.
  14. #14 Re: Replacement lifters? Texas Speed?
    Pennsylvania
    LS7 (because it has 8 cylinders) would be 16, other one's 12.
    Inspect your lifters.
    You might not like what you find.
  1. Lim and lifters replacement preperation
    By GTP2G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2012, 11:23 PM
  2. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  3. Left rear speed sensor replacement
    By steverichmond in forum General Tech Discussion
    Last Post: 10-25-2010, 04:46 PM
  4. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  5. Lifters
    By 2000 Black 2dr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2010, 01:12 PM
