Thread: Quick question guys...
Results 1 to 8 of 8
  1. #1 Quick question guys...
    Arkansas
    ...what is this? I've tried to find out for quite some time with no luck. I am looking do do a quick and cheap air intake fix (there is an open hole on the hose where apparently another one of these parts is supposed to go, and the lip/connector to the throttle body is cracked). I can't seem to find a replacement intake tube anywhere so I have to go the aftermarket route.
    Anyway, thanks for the help.
  2. #2 Re: Quick question guys...
    can't see pictures from work...'97-'03 or '04+?
  3. #3 Re: Quick question guys...
    Arkansas
    '97-'03
    '98 to be exact.
  4. #4 Re: Quick question guys...
    That's an air tube herpe. Otherwise known as a baffle etc. It's sole job TMK is to keep the intake noise quiet.
  5. #5 Re: Quick question guys...
    Arkansas
    So it's not really needed? I assume that's why I don't see it on aftermarket or user-made intakes.
    Not sure if an aftermarket intake would fix my throttle body lip problem though. If they connect directly to the throttle body then it would, but if not I'm stuck.
  6. #6 Re: Quick question guys...
    Yup, just a silencer.
    Rip it out and just bolt a cone on the TB and enjoy the blower whine.
  7. #7 Re: Quick question guys...
    Arkansas
    Ah that is good news then, I guess that's why I rarely see it on other GTPs. Thanks
  8. #8 Re: Quick question guys...
    The reason you rarely see it is
    1. Most got rid of it.
    2. 99-03 got a different accordian that was much less restrictive than the one you have there.
  1. Replies: 2
    Last Post: 12-10-2011, 03:28 PM
  2. Quick WOT question
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 12-09-2011, 09:10 PM
  3. hey you guys quick ?
    By Bluemagic in forum General Tech Discussion
    Last Post: 01-01-2011, 04:12 PM
  4. quick question guys.
    By tazyboy28 in forum Off Topic Discussion
    Last Post: 11-30-2009, 03:29 PM
  5. Quick Question
    By Bakerdd in forum General Tech Discussion
    Last Post: 07-18-2009, 12:03 AM
