Thread: supercharger play?
Results 1 to 12 of 12
  1. #1 supercharger play?
    Mar 2012
    michigan
    bought a 98 regal gs sc 3800 motor blown by previous owner when u trun sc pulley back and forth it kinda clicks like ther is play is that bad can anyone take ther belt off and see if when u turn it bak and fro if it clicks
    thanks
    98 REGAL
  2. #2 Re: supercharger play?
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    its most likely its a coupler bud
    its an easy fix ill find a link
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  3. #3 Re: supercharger play?
  4. #4 Re: supercharger play?
    Nov 2010
    Maryville, MO
    // 2005 Comp G
  5. #5 Re: supercharger play?
    Mar 2012
    michigan
    hexx yeah dude thats cake but from the vid the coupler looks likeit just sits on those 3 pins correct?thanks alot guys will def change it while its off car
  6. #6 Re: supercharger play?
    yup just like you see it, 3 pins holds it on the gear, then 3 more pins are on the end of the sc pulley shaft, that slides into the 3 open holes left in the coupler, search ebay for the coupler, i got mine for 21 bucks shipped, went to a gm dealer for the sc oil, get 2 cans, you need 1 and 1/2 bottles, more or less. get a green coupler, not a black one.
  7. #7 Re: supercharger play?
    yeah it just sits on the pins and lines up with the pins on the snout.
  8. #8 Re: supercharger play?
    Mar 2012
    michigan
    i see its 15 every where on the net is autozone gonna be same or close or no
  9. #9 Re: supercharger play?
    Mar 2012
    michigan
    autozone 16 99 thanks guys il de be doin the coupler before hand
  10. #10 Re: supercharger play?
    auto zone is going to have the stock coupler, were yes it will work just fine, but the green zzp style coupler lasts a lot longer.
  11. #11 Re: supercharger play?
    Mar 2012
    michigan
    ok thanks alot i actually live 1 hr away from zzp in gr michigan prolly contact them about pcm and coupler
  12. #12 Re: supercharger play?
    Nov 2010
    Maryville, MO
    that works good luck with everything
    // 2005 Comp G
  1. Oem nav play dvd's?
    By carriaga89 in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2012, 09:45 AM
  2. Who wants to play?
    By GAFF in forum Off Topic Discussion
    Last Post: 05-20-2010, 06:23 PM
  3. how to play an mp3 cd
    By jfhghs in forum Audio, Security & Visual Electronics
    Last Post: 08-24-2009, 10:24 PM
  4. Anyone play Airsoft?
    By Sabrewings in forum Off Topic Discussion
    Last Post: 01-22-2009, 07:08 PM
  5. End play in crankshaft?
    By BackInBlack in forum Off Topic Discussion
    Last Post: 11-01-2008, 08:04 PM
