I have a 97 GTP. I have a blinking SES light that blinks several times. The code is P0300 (could be wrong) but I know the only code that gets thrown is the Random/Multiple Misfire code. Ive had it scanned and two different places both with the same results. So basically I started from the top to fix that code.
Stuff Ive done:
1. Spark plugs (NGK Irridium)
2. Spark leads
3. Fuel Pressure Regulator (it was seized up)
4. The 1 and 4 Coil Pack (#1 had some rust)
Then one day, on another trip to get codes ran again, smoke starts coming up from the center console. I pulled over, shut off the car, look underneath the car and my catalytic converter was cherry red. Pretty scary having that happen but then I thought to myself, maybe thats it!Oh and during this whole time my car has a sever loss of power and getting about nine MPG with the smell of gasoline. Since then Ive replaced the cat and both o2 sensors. Let it run for like three minutes and watched the cat. Smoke comes off the brand new cat and Im still smelling gasoline along with that irritating SES light.
My conclusion is the misfire is so bad that it cant burn the gas (poor MPG and power loss) so it gets dumped out of the exhaust and causing the cat to go bad. I have no idea how to solve the misfire. Ive never worked on the inside of an engine before so detailed information would help me out a lot. Please before I decide to blow this car up.
