Thread: Lim and lifters replacement preperation
Results 1 to 12 of 12
  1. #1 Re: Lim and lifters replacement preperation
    Won't matter.
    You should probably flush the system till clean water comes out then fill with coolant till you reach 50/50.
    I use dexcool in my engine cooling system and prestone long life in the intercooler system so I can tell which system is leaking.
    Aside from that, you should be fine with either one.
    I do not suggest cheap long life coolant or ethylene glycol. I used the latter for a couple months before pitting in the supercharger case developed.
  2. #2 Re: Lim and lifters replacement preperation
    SE Level Member GTP2G's Avatar
    louisville ky
    Prolly a dumb question but I should flush the system after I'm done with everything right?
  1. What lifters to use?
    By Bob Padilla in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 10:54 PM
  2. lim gasket preperation
    By gtcoup in forum General Tech Discussion
    Last Post: 02-20-2011, 01:37 PM
  3. Lifters
    By 2000 Black 2dr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2010, 01:12 PM
  4. Bad Lifters?
    By BDEGhost in forum General Tech Discussion
    Last Post: 11-04-2009, 07:46 PM
