Thread: Gremlins please help
Results 1 to 15 of 15
  1. #1 Gremlins please help
    Donating Users SarasotaGTP's Avatar
    Nov 2011
    Sarasota Florida
    Okay so I changed out the battery cables a few days ago and thought that solved my ltft 16.4 and P0171 problems but they are back. My scan tool is flashing 2 emission monitors and they are htr and O2S. I have read enough to know that the O2 sensor is usually a misdiagnosed cause of the P0171. I am as sure as I can be that there is no Vac leaks anywhere, checked all vac lines checked egr even checked the oil dipstick to make sure it was sealing in the tube and nothing. I hate shotgunning parts but read about the IAT and the ECT as possible sensors that could alter the trim levels as well as how the the O2 sensor data effects it as well.
    To give a rundown on things already done
    Lim/sc/tb gaskets all vac lines replaced
    MAF, IAC, TPS, CAM sensors replaced
    Have switched between 3 seperate PCM's - 2 stock 97 pcm's and a tuned 97 with a mild tune and all the parameters are essentially the same with any of the 3 PCM's
    I am at a loss what to do next. My rpms have a little fluctuation maybe + or - 150 at most at idle but not enough to really think CPS but if the CPS can effect fuel trims then I'll go ahead and change that but I am stumped.
    Thanks
  2. #2 Re: Gremlins please help
    Quincy, Mass
    an exhaust leak before the front o2 sensor can cause this. and just because most of the time its not the o2 doesnt mean its not this time.
    No more GP 04 Impala SS Indy:
  3. #3 Re: Gremlins please help
    when does the flogging begin?
    Any codes for the O2 or is it just the monitors/tests that aren't ready yet?
  4. #4 Re: Gremlins please help
    Nov 2011
    Sarasota Florida
    lol flogging has been continous since issue returned. No codes at all not even the P0171 yet but I am sure that is a matter of time. I am embarassed to say that I don't know 100% how my scan tool works but from what I can tell the monitors are flashing cuz they can't function to test which is why I am thinking o2 sensor but I dunno. I unplugged the iat and ect last night and the temp reading went to negative 39 at startup so I assume they are at least working at this time but they could be working yet faulty???
  5. #5 Re: Gremlins please help
    The sensors can go bad, however typically they are pretty robust. Like how I said..yes and no at the same time?
    I'm a bit happier since you don't yet have the code. Not a bit happier about how much I drank last night.. it's kinda a rough morning. Try watching the O2 sensor with the car running/driving. It should fluctuate up and down.. say 100mV to 800ish.
  6. #6 Re: Gremlins please help
    Nov 2011
    Sarasota Florida
    Well get some damn coffee and help me with my car. It is not my problem how much you drank last night. Didn't you take into account that it had been about 2 days since I had posted an issue with my car. You should have planned on this coming today and not drank so much so you could be of more help. Jeez some people!
    Oh and Swiggles thanks for the info I appreiciate it. It is just kinda Bill's responsibilty to offer up suggestions to get my car running and into the high 11's with my stock setup since I took his advice and changed the battery cables what a goofy azz idea that was.
    BTW I am 100% kidding with the smatazz stuff just in case anybody was wondering, although the 11's would be sweet but I'd rather have my damn trims where they are supposed to be at the moment.
  7. #7 Re: Gremlins please help
    I got the code to go away. ... you said trims are fluxing. Not that it set a code. Job accomplished lol
    Did you pick up a fuel pressure tester the last time you were at HF?
  8. #8 Re: Gremlins please help
    Nov 2011
    Sarasota Florida
    Nope but I did just get my monthly booklet so there may be a reason to go again and get rid of a coupon or two dozen at HF. Could my fuel pump be doing this? I have had the relay pin bent since almost buying the car but never really thought about that much. For all I know and assume the car was running 16.4 when I bought it but it could have changed when I bent the pin to set pump on high
  9. #9 Re: Gremlins please help
    Your running with more of a supply, that's all that's going on. So is my car , I don't have any LB1 symptoms.
  10. #10 Re: Gremlins please help
    Nov 2011
    Sarasota Florida
    showoff
  11. #11 Re: Gremlins please help
    heck..my fuel trims are even dialed in.
  12. #12 Re: Gremlins please help
    Nov 2011
    Sarasota Florida
    fine go ahead and kick a guy while he's down that's okay. I'm gonna make a avatar with a barney head and your pokemon guys body, I'll show you
  13. #13 Re: Gremlins please help
    So the only thing you haven't check that is a possibility...seems like pressure.
  14. #14 Re: Gremlins please help
    Nov 2011
    Sarasota Florida
    ok so rtv'd the frik out of the egr area and my ltft at idle is -.5 now stft is 0 should I sell it now?
  15. #15 Re: Gremlins please help
    Nov 2011
    Sarasota Florida
    I will check pressure too but have not yet. You are right oh wise one.
  1. Need help with some electrical gremlins
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2012, 11:10 AM
  2. Oil gremlins
    By 2fargone in forum General Tech Discussion
    Last Post: 09-20-2011, 05:50 PM
  3. power window gremlins
    By Scottydoggs in forum General Tech Discussion
    Last Post: 07-05-2011, 02:52 PM
  4. Electronic Gremlins
    By Joe Limon in forum Audio, Security & Visual Electronics
    Last Post: 09-01-2010, 08:43 PM
  5. ABDS/TCS gremlins
    By marchi1 in forum Brakes/Suspension/Chassis
    Last Post: 01-07-2008, 07:00 AM
