Thread: zzp Gen 5 to L67/L36 Throttle Body Adapter Plate
Results 1 to 11 of 11
  1. #1 zzp Gen 5 to L67/L36 Throttle Body Adapter Plate
    Kemmerer, Wyoming
    I'm just wondering if anyone has used this for their gen 5 swap. they claim the pcv will function normally with this part and no machining necessary.
  2. #2 Re: zzp Gen 5 to L67/L36 Throttle Body Adapter Plate
    By the time a gen V is beneficial, a stock TB isn't worth using.
  3. #3 Re: zzp Gen 5 to L67/L36 Throttle Body Adapter Plate
    Vancouver, WA
    Quote Originally Posted by johntremell View Post
    I don't believe that is true. The PCV on the back of the Gen V connects to the stock L32 TB. There is not a place for this connection on a stock L67 TB, the TB will need modded so that there is an extra nipple after the TB blade.
    Slowest 'Cooled Gen V ever
  4. #4 Re: zzp Gen 5 to L67/L36 Throttle Body Adapter Plate
    Quincy, Mass
    isnt that nipple on the zzp adapter plate?
    No more GP 04 Impala SS Indy:
  5. #5 Re: zzp Gen 5 to L67/L36 Throttle Body Adapter Plate
    Kemmerer, Wyoming
    [By the time a gen V is beneficial, a stock TB isn't worth using]
    I'm already running a ported tb and spacer.
  6. #6 Re: zzp Gen 5 to L67/L36 Throttle Body Adapter Plate
    The adapter plate nipple is for Evap. Aka post maf and post throttle blade.
    I recently tapped mine in and IIRC it's post maf and before the throttle blade.
    If you look at a stock L67 TB, you can follow the passage.
    Smaller than a 3.4 pulley?
  8. #8 Re: zzp Gen 5 to L67/L36 Throttle Body Adapter Plate
    Kemmerer, Wyoming
    The adapter plate nipple is for Evap. Aka post maf and post throttle blade. I recently tapped mine in and IIRC it's post maf and before the throttle blade.
    Sorry for my retardedness but does this cover us to run the gen 5
  9. #9 Re: zzp Gen 5 to L67/L36 Throttle Body Adapter Plate
    Well.. mostly.
    You need the correct length bolts because 3 of the ones in a Gen V are longer than their Gen 3 counterparts.
    You can run the stock Gen V evap and not need to use the nipple on the adapter if you have an L67/L36 TB
    The gasket for Gen V to LIM
    Opening up an L67 LIM for the larger opening of the Gen V
    97/98 needs the newer alternator and it's bracket/tensioner
    You'll want to think about a CAI, but I can confirm that the stock accordian tube and air box will fit with a Gen V and L67 with adapater plate. (I just did it, but don't recommend it)
    I think that covers it.
  10. #10 Re: zzp Gen 5 to L67/L36 Throttle Body Adapter Plate
    Kemmerer, Wyoming
    thanks for the help. that answers all my questions. I did the wizaired cai and the ported tb, I also have a tb spacer. the lim came with the gen 5. and the car is a 99 so I think the alternator bracket will be ok.
    Again, thanks for the help.
  11. #11 Re: zzp Gen 5 to L67/L36 Throttle Body Adapter Plate
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    i just want to have everything worked out for the pcv issue and i was told tap a line into the l67 tb
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
