Thread: Ooh was so close! No start
Results 1 to 6 of 6
  1. #1 Ooh was so close! No start
    Wichita
    Got the car completed late last nite. =] Then I started it & it won't start. It just keeps turning over & over. It's got gas. The battery is charged. It's as if it's not getting spark. I'm positive everything on the harness is plugged in. Any ideas or suggestions on how to find the problem?
  2. #2 Re: Ooh was so close!
    Yoga city
    double check connections everywhere.
  3. #3 Re: Ooh was so close!
    PA
    Pull a plug and make sure you are getting spark. And when it is out, make sure the plugs are wet with fuel to know the injectors are firing.
    2001 GSE
  4. #4 Re: Ooh was so close!
    check the ICM connection, if it's loose..you may not have spark. If you unhooked the pcm, double check that. Then either pull a plug or check for fuel injector pluse
  5. #5 Re: Ooh was so close!
    Wichita
    Thanks for all the input! I'll check all of those things
  6. #6 Re: Ooh was so close! No start
    Wichita
    The issue was a bad TPS and a frayed wire had grounded itself. Problem solved and car runs great now =]
  1. is anybody close to this?
    By Below Average Joe in forum Midwest
    Last Post: 10-28-2011, 02:50 PM
  2. How close would this be?
    By tyv193 in forum Off Topic Discussion
    Last Post: 07-30-2010, 01:37 PM
  3. So close to 13's...help me out
    By real diehl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 08:49 AM
  4. Am I getting Close
    By PontiacGTPSE in forum General Tech Discussion
    Last Post: 10-26-2009, 06:09 PM
  5. Ugh!! I'm SO CLOSE!!!
    By BwolfGT in forum Off Topic Discussion
    Last Post: 09-24-2009, 11:59 AM
