Thread: No start question
Results 1 to 14 of 14
  1. #1 No start question
    Dec 2011
    chicago
    I have a 98 gtp and this morning the car wouldnt start. I checked for fuel pressure at the rail and there was nothing. So I bought a delco fuel pump and installed. Still nothing. I tried hooking a scanner up and it would not connect. The fuel gauge is also pegged at full but there is only a 1/4 tank of gas in it. When I key the car up, the mpg on the DIC say what it should be and then a few seconds later it flashes "0.0". Has anyone else encountered this before? Thanks
  2. #2 Re: No start question
    Check the cig lighter fuse for the OBD2 port.
    Have you looked at the relay for the fuel pump yet????
  3. #3 Re: No start question
    Dec 2011
    chicago
    yea I just tried swapping relays and still nothing.
  4. #4 Re: No start question
    St. Louis
    Check all the fuses in the car and under the hood. Might have popped one.
  5. #5 Re: No start question
    Dec 2011
    chicago
    I didnt splice in the pigtail that came with it because the one that is on there is Identical. Might that be the problem? Is there a reason to change it if its the same?
  6. #6 Re: No start question
    St. Louis
    I take it you mean the pigtail for the FP? As long as the pinouts are the same on both the pump and the harness side then I'd see no reason to. If it's like my 95 Bonne there is 4 wires in the harness. 2 for the fuel level sender and 2 for the FP.
  7. #7 Re: No start question
    Dec 2011
    chicago
    its an identical connecter. I know some car and aftermarket pump have different connecter that why I went with the OE delco.
  8. #8 Re: No start question
    St. Louis
    Time to check for ground and power at the harness maybe. Might have one not quite right. The fact that the fuel gauge is pegged at full and the pump won't run almost makes me think that something in the wiring is crossed, even though the harness is the same. Do you have a book that shows the electrical system and wiring colors? Then you would know which 2 are for the pump on the harness side and make sure that the same 2 wires coming FROM the pump are connecting to the same 2 on the harness.
    I could be off but I've seen strange things even w/ OEM stuff. Mid-year changes, etc... Did you take a look at all your fuses yet?
  9. #9 Re: No start question
    St. Louis
    After my own research it appears that there are 2 harnesses that connect to the fuel pump, not just one like on the older cars so my bad there. I did however find something that may help. Of course this is for a GT, but it was a 98. I can't see the GTP being any different.
    The gray,green,orange 3 wire connector is for the fuel tank pressure sensor. The other 4 wire square plug is for the pump and level sender. This may help.
    Fuel Tank, C1
    Connector Part Information
    • 12160482
    • 4-Way F Metric-Pack 150 Series Sealed (BLK)
    Pin
    Wire Color
    Circuit No.
    Function
    A
    PPL
    30
    Fuel Gauge Sensor Signal
    B
    GRY
    120
    Fuel Pump Motor Feed
    C
    BLK
    150
    Ground
    D
    BLK/WHT
    651
    PCM Sensor Ground
    Fuel Tank, C2
    • 12059595
    • 3-Way F Metric-Pack 150 Series (BLK)
    Pin
    Wire Color
    Circuit No.
    Function
    A
    ORN/BLK
    469
    PCM Sensor Ground
    B
    DK GRN
    890
    Fuel Tank Pressure Sensor Signal
    C
    GRY/BLK
    416
    5 Volt Reference
  10. #10 Re: No start question
    Dec 2011
    chicago
    i just checked for in injector pulse and got nothing either
  11. #11 Re: No start question
    Dec 2011
    chicago
    I also checked all the fuses and the scan tool still will not communicate. I was fine before the problem started though.
  12. #12 Re: No start question
    Dec 2011
    chicago
    theres no power at the fuel pump but theres power at the fuse. it has spark but no pulse.
    Flashing zero on the dic suggests dead pcm
  14. #14 Re: No start question
    Dec 2011
    chicago
    Is there a TSB in regards to the Pcm?
  1. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  2. remote start question
    By reikokitkat in forum Audio, Security & Visual Electronics
    Last Post: 11-17-2009, 02:00 AM
  3. QUESTION about FIRST START UP
    Last Post: 09-12-2009, 04:57 PM
  4. Question about shaking on start up
    By robromano in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2009, 11:14 AM
  5. Grand Prix newb with a start off question
    By PontiacBoy13 in forum Introductions/Noob Questions
    Last Post: 08-24-2008, 08:16 PM
