Thread: Valve cover gasket question
Results 1 to 12 of 12
  1. #1 Valve cover gasket question
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    I replaced my valve cover gaskets when I did my lim gaskets three months ago. I noticed that I have oil on my front exhaust manifold from a leaky valve cover gasket. I got the gaskets from zzp for 20.00 and also replaced the bolt grommets. I plan on replacing the gaskets again since there leaking but am wondering if I should go with a different gasket maker, I'm thinking of picking up the felpro kit for 50.00 from advance auto but am wondering if it's the same thing is get from zzp. Anybody else have a problem with the zzp valve cover gaskets?
  2. #2 Re: Valve cover gasket question
    I did.
    Bought felpro's and they've been fine ever since.
  3. #3 Re: Valve cover gasket question
    St. Louis
    I'll second the Fel-Pro's. I installed their gaskets and grommets on my GT when I replaced the motor and its been dry ever since.
    Dec 2011
    Grand rapids Mi
    I guess I'll be putting the Felpros on this weekend. I guess you really do get what you pay for.
  5. #5 Re: Valve cover gasket question
    ZZP made gaskets for their aluminum valve covers and they fit those covers perfectly. In the stock covers.. here's what you get
    Dec 2011
    Grand rapids Mi
    I thought they fit kind of crappy around the corners but I figured they would seal when torqued down. I can't see if my rear cover is leaking but I'm assuming if the front one is the back is probably leaking as well.
    Dec 2011
    Grand rapids Mi
    Ok so I changed out the zzp gaskets for some felpro gaskets and sprayed the exhaust manifold with a degreaser to get the oil off the exhaust. I looked at it today after driving it quite a bit and noticed the manifold looked wet again. Is it possible it's still leaking even after changing the gasket? Is there somewhere else this oil could be coming from like exhaust gasket? I attached pictures to show where's it's coming from. It's not a lot of oil but it's enough to drive me crazy.
  8. #8 Re: Valve cover gasket question
    SE Level Member rodneypierce's Avatar
    Jan 2012
    Cedar rapids, IA
    Try driving it for a week or so and see if the spot gets worse. Its hard to tell from those pictures, but that doesnt really look like its soaked in fresh oil. So might be residual seeping out of the cast iron maybe? Give it a week or so and check on it again.
    1998 GTP. Stock.
  9. #9 Re: Valve cover gasket question
    Wichita
    Don't ever buy those cheapo black valvecover gaskrts from zzp. I found out the hard way that they always fail. Now I buy felpro.
  10. #10 Re: Valve cover gasket question
    When you replaced them.... say you changed the grommets too.
    Dec 2011
    Grand rapids Mi
    Yeah I changed them when I put on the zzp gaskets and changed them again when I did the fel pro gaskets.
  12. #12 Re: Valve cover gasket question
    Wichita
    Ditto
  1. Valve cover gasket
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2011, 05:11 PM
  2. Valve cover gasket replacement
    By Burgundyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 07:06 AM
  3. Valve cover gasket Recall
    By Dexter in forum Off Topic Discussion
    Last Post: 01-17-2010, 12:55 AM
  4. Valve cover gasket
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 10:25 PM
  5. valve cover gasket
    By BFish in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-12-2008, 03:51 PM
