Thread: gen 3 engine into 98 gtp
Results 1 to 17 of 17
  1. #1
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Welcome to Gpf, where your questions usually Ger answered with a link...lol.
    Lemme try to help...
    First off, let's get some terminology right. The gen2 engine is known as the L67, the gen3 as the L32. The reason we don't use "Gen" to refer to the different engines is because that term is commonly used to describe the superchargers on this engine. Your L67 came equipped with what we can a gen3 Eaton supercharger. Where as your L32 came with a gen5 Eaton.
    you will need to find an adapter plate for ur l67 throttle body to bolt up to the L32 supercharger. Or you can upgrade to an ls1 of northstar throttle body.....all requiring an adapter plate. The reason u can't use the gen3 TB is that its drive by wire...
    Also fueling needs some changes too. The 04 is a return less system, therefore the fuel rail from the 04 will have to be swapped with your 97-03. Additionally, the fuel injectors on the L32 have different connections, so u will need to swap injectors also.
    Vacuum system also needs some tweeking....look up my "Gen v supercharger thread" for some detailed info on what u need to do for that.
    Wiring should be pretty plug and play...I do believe the engine temp sensor in the lim was changed, so u may need to swap out that sensor as well.
    That's all I can really think of off the top of my bead. Hopefully others will chime in with more useful information....and no more links.
    Sent from my sweet DROID Razr Maxx
    For all your 3800 needs:
  2. #2 Re: gen 3 engine into 98 gtp
    Feb 2009
    flintnasty MI
    Quote Originally Posted by copgtp View Post
    Wrong wrong wrong.
    Just put your old fuel rail and injectors on... There is no swapping to be done... If you wanted to make everything really easy, just put your old gen3 blower on and you will have nothing to change over. You can usually sell those gen5 blowers for alot of money.... I have bought quite a few series3s for free after selling the gen5 on top...
  1. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
