Thread: 2 crank sensors?
Results 1 to 7 of 7
  1. #1 2 crank sensors?
    GT Level Member m17davis's Avatar
    Orland Park, IL
    i am not getting injector pulse and i was wondering if there were 2 different sensors. i thought there was one that goes to the icm and one that goes to the pcm. its a 2000 gtp. ive replaced the fuel pump resistor, camshaft sensor, maf, map, and iac sensors. also replaced injector fuse and fuel pump relays.
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: 2 crank sensors?
    Omaha, NE
    You should only have 1.
    I suspect ICM, Grounds or Tune.
  3. #3 Re: 2 crank sensors?
    Orland Park, IL
    thanks. I've had the icm tested tested already. And I have spark also just no pulse.
  4. #4 Re: 2 crank sensors?
    Charles City, IA
    find a wiring diagram for your car and make sure you have injector pulse at the pcm and icm. you could have a bad pcm.
    SMGPFC Two Nipple General
  5. #5 Re: 2 crank sensors?
    Orland Park, IL
    I put the stock pcm back on and It didn't change anything. I'm going to test the crank sensor tomorrow and ill update.
  6. #6 Re: 2 crank sensors?
    Sep 2011
    MI
    Did you check all your fuses FIRST?
  7. #7 Re: 2 crank sensors?
    Orland Park, IL
    Yes. Fuses and relays are good. I have power at the injector plug just no pulse.
  1. 02 sensors
    By artsy in forum General Tech Discussion
    Last Post: 06-14-2010, 06:24 PM
  2. O2 sensors
    By Poil336 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-29-2009, 10:30 AM
  3. I want your sensors
    By SyntheticShield in forum General Tech Discussion
    Last Post: 02-05-2009, 01:53 PM
  4. 2 map sensors??
    By sickofsoyo in forum General Tech Discussion
    Last Post: 01-24-2009, 09:28 PM
  5. sensors?????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 09-28-2008, 01:00 PM
