Thread: thoughts for cam
Results 1 to 13 of 13
  1. #1 thoughts for cam
    SE Level Member Hawkman's Avatar
    Jun 2010
    North east, WI
    just was wondering what you guys think of this cam for a supercharger setup here are the specs! thanks
    comp cam vsc 2002-1
    intake exhaust
    .512 .520
    duration @ .006 tappet lift .257 .263
    valve timing open close
    @.050 int -7 btdc 33 abdc
    exh 42 bbdc -10 atdc
    specs are for cam installed @ 110.0 intake center line
    intake exhaust
    Duration @ .050 206 212
    lobe lift .3200 .3250
    lope separation 113.0
    all stock just as the car was intended!
  2. #2 Re: thoughts for cam
    Omaha, NE
    Sounds slightly smaller than an XP.
    ZZP's XP page states:
    Look for gains of 40-55 hp depending on your car's current configuration.
    •212°/224° at .050"
    •Intake Lift .325" (.520" lift at 1.6:1 rocker ratio)
    •Exhaust Lift .335" (.536" lift at 1.6:1 rocker ratio)
    •116 Lobe Separation
    Edit: It is comparable to a VS
    •206/216 at .050"
    •Intake Lift .320" (.512" lift at 1.6:1 rocker ratio)
    •Exhaust Lift .317" (.507" lift at 1.6:1 rocker ratio)
    •115 LSA
  3. #3 Re: thoughts for cam
    Jun 2010
    North east, WI
    So this will work for a supercharged application? Thanks not to familiar about cam specs yet! So any help is appreciated! So this is basically a modified cam to be similar to the vs and just has a tighter lsa? Just wanting to verify this not a n/a cam
  4. #4 Re: thoughts for cam
    it'll work. normally with a blower application you want a little more exhaust lift than intake lift.
  5. #5 Re: thoughts for cam
    Jun 2010
    North east, WI
    Ok cool so this actually better than a vs cam than! ? Also comp 7.00. Push rods will be used with it! So this will be kinda in between cam of a vs and xp right?
    Lift wise, yeah. I don't understand the rest of the specs too well myself, though to tell you the real differences.
    Where did this cam come from?
    Lots of negative overlap. Will be very dd friendly.
  8. #8 Re: thoughts for cam
    Oil Restricted Pushrods.
    yay.
  9. #9 Re: thoughts for cam
    Nov 2011
    NY
    Lol, not to hijack the thread, but this made me think... has anyone tried this with just a Rocker install?
    Say, 1.84's Intake, 1.9's Exhaust on a stock cam?
  10. #10 Re: thoughts for cam
    Jun 2010
    North east, WI
    What kinda performance gain could I expect from this cam and would a vs be a better cam to go with? The cam seems like a mix between a vs and a intense s1 cam if I'm not mistaken? Thanks
  11. #11 Re: thoughts for cam
    gains will be good. the difference in power between all the cams mentioned in this thread are not that much.
  12. #12 Re: thoughts for cam
    Florida
    i think this is what ZZP does with their ER rockers.... the diff intake and exhaust rocker ratio.... the split ratio
  13. #13 Re: thoughts for cam
    Nov 2011
    NY
    Quote Originally Posted by Z34Phoenix View Post
    Interesting...
    thanks!
  1. My thoughts on E85 GTP's
    By OrangeL67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2011, 12:38 AM
  2. I Want your thoughts.
    By shawngtp in forum Tires & Wheels
    Last Post: 11-08-2010, 09:29 AM
  3. Thoughts on 12's
    By grannyprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2010, 02:43 PM
  4. Thoughts on 911.....
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 09-21-2010, 07:03 PM
  5. Well I Need Some Thoughts...
    By SlickGTP in forum Off Topic Discussion
    Last Post: 01-14-2008, 01:28 AM
