Quote Originally Posted by GTPluv View Post
Thanks guys!!!
Shawn, good maintenence to me is oil change and the occasional plug/wire change. haha Don't fix what aint broke. I've had the TA since it 30k miles on it and the Check Engine light has always been on because the O2 sensor. So, I figured, it runs fine, I must not need it. To me, 30k mi is still a new car. right.
TDC you lost me on the whole bank thing???
What is a DENSO?
Thanks still!!!!!
The "bank thing" is just discussing your different oxygen [O2] sensors on your exhaust system.
-Bank 1 sensor 1 is the O2 sensor on your rear exhaust manifold.
-Bank 2 sensor 1 is the O2 sensor on your catalytic converter [aka cat].
If the one on your catalytic converter is giving you a code you may have a bad cat if im not mistaking. [can anyone corroborate this?] Your symptoms are smiler to a bad cat. I beleive a bad fuel filter would also give you a smiler problem although most likely not the case because of your code.
Also Denso is the company where you can get your O2 sensor from. Iron Indian is giving you a site, a name brand and a coupon code so you can order an O2 sensor online for cheaper then local stores.
