Thread: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
Results 1 to 19 of 19
  1. #1 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    phoenix,az
    ok guys i have a 2000 grand prix gtp and it wont start.... ive narrowed down the problem to the fuel pump relay and pcm.. the pcm does not give power to the relay to energize it... ive already checked the ground to the relay and it turned out good... also a wierd thing ive noticed is that if i take the relay out, the pcm will supply power but as soon as i put the relay back in, the pcm no longer gives power to the relay... any ideas? THANKS
  2. #2 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    did you buy a new relay?
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    phoenix,az
    yup... actually i bought two. (one for the fuel pump and another fo the fuel pump
  4. #4 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    phoenix,az
    one for fuel pump and another for fuel pump spd control*
  5. #5 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    brunswick
    when i had this problem my fuel pump completely died on me... thats what it sounds like in this case... i brought relays too but still had my problem.. changed the pump and smooth since....
  6. #6 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    phoenix,az
    yeah that was what i was going to do but i noticed the pump wasnt even getting power at the connector... wierd
  7. #7 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    brunswick
    yea thats true too.. has the pump been replaced at all?
  8. #8 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    phoenix,az
    no... only thing i replaced was the fuel filter
  9. #9 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    Take a look at the diagrams. I am seeing the pcm supplying only ground to control the pump.
  10. #10 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    phoenix,az
    im using a different wiring diagrm than that one
  11. #11 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    Care to post it so we can join you in the info?
  12. #12 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    phoenix,az
  13. #13 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    phoenix,az
    i dont have power at A5
  14. #14 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    Hmm have you checked all the expected inputs of power to the pcm? I've never found anything clear on the supplies to the PCM as to what they are used for and supply when they come out of the pcm.
  15. #15 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    does the fuel guage work? my guess would be try chaqnging the pump....also there is some type of resister under the front bumper by the windshield washer bottle...maybe faulty....also id look at ignition... if all these check out change the pcm.... my bet would be the pump tho. we know they are notorious
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  16. #16 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    Quote Originally Posted by mikedinthecity View Post
    He said he's not getting power to the connector going to the pump. Should rule out the pump.
    Said he isn't getting power to the relay, which can not relay the higher power to the pump.
    Resistor would cause the car to have a litle furl to start and run for a couple seconds then die each time the ignition is cycled from on to start and back off.
    Ignition is a possibility if it feeds the power the pcm uses to send to the relay.
    Wiring is possible as it might be leaving the pcm and have a short from the pcm to the fuel panel.
    PCM is also suspect.
  17. #17 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    phoenix,az
    Yeah the fuel gauge works fine. i dont think its the pump... also a weird think i noticed is that with the relay out, i do have power at A5 but as soon as i put the relay back in, A5 no longer has power
  18. #18 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    Reminds me of a bad ground or bad power.. It looks fine until you put a load on it.
  19. #19 Re: 2000 grand prix gtp fuel pemp relay/pcm problem PLEASE HELP!!!!!!!
    phoenix,az
    I'll double check the power and ground but i think the problem is the pcm....
  1. 2000 grand prix gtp fuel pemp realy/pcm problem PLEASE HELP!!!!!!!
    By Albertg9 in forum Introductions/Noob Questions
    Last Post: 02-17-2012, 07:39 AM
  2. 2000 GTP fuel pump relay problems
    By torqueaddict in forum General Tech Discussion
    Last Post: 06-11-2011, 07:14 PM
  3. 2000 Grand Prix GT Fuel Gauge
    By Hozer1980 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2011, 06:32 PM
  4. 2000 Grand Prix Fuel Gauge
    By Hozer1980 in forum Off Topic Discussion
    Last Post: 03-21-2010, 07:12 PM
