Thread: dumb question but?
Results 1 to 20 of 29
  1. #1 dumb question but?
    Palmdale
    How hard can I pull on this before it breaks,, it is on there pretty good. Watching the how to video but they do not show how to get it off.I am trying to change my LIM gasket. Any thing will help
  2. #2 Re: dumb question but?
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    You don't need to remove that when doing LIM gaskets...
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  3. #3 Re: dumb question but?
    Palmdale
    well I have to do the the UIM (SC gasket) gasket too. So either way it does not have to come off.
  4. #4 Re: dumb question but?
    Grand Rapids, MI
    It stays on the blower..
  5. #5 Re: dumb question but?
    Palmdale
    I was a bit unclear guys the hoses is what I was talking about and not the sensor.
  6. #6 Re: dumb question but?
    Grand Rapids, MI
    The hose going to the boost bypass valve stays on, the one going to the firewall pops out easily with a flat head screwdriver. thats all you need to remove.
  7. #7 Re: dumb question but?
    Mercer, Pa
    Twist the hoses then pull. A twist will break them loose and then you should be able to pull them off. You might want to use a pair of needle nose pliers and push the vacuum hoses off. Hoses are easier to fix then the vacuum fitting on the supercharger.
  8. #8 Re: dumb question but?
    Palmdale
    ty sorry for being pain!
  9. #9 Re: dumb question but?
    Palmdale
    also do you have to get the gas out of the lines going to the injectors. Reading the Haynes manual it tells you to releive the gas pressure. iDo i really have to do this part. The bad thing is I have taken the belts off and drained radiator already.
  10. #10 Re: dumb question but?
    SE Level Member jaked1985's Avatar
    Jan 2012
    West Union, Iowa, United States
    You are disconnecting the fuel rail to replace the lower gaskets, correct? All you have to do is push on the bleeder in the fuel rail to relieve pressure.. They are probably telling you to get it all out to avoid getting any in the oil?.... But, if ur gonna do the work, change ur oil when ur done...
  11. #11 Re: dumb question but?
    Palmdale
    Quote Originally Posted by jaked1985 View Post
    Yes I am will be disconnectiong the fuel rail, thanks for the advice on how to relieve the pressure. This is my first time working on this car and do not want to screw up anything. Once I am done I have to do the water pump too. Should be fun. As I go I am labeling everything and taking pictures. I am going to watch that video again.
  12. #12 Re: dumb question but?
    Jan 2012
    No prob. I'm new around here, but I've been turning wrenches for quite awhile. Alot of the same things apply for any vehicle. Just take ur time when ur working on the motor... Labeling things and taking pics can be a huge help on the assembly process.
  13. #13 Re: dumb question but?
    Palmdale
    Quote Originally Posted by sseilmnop View Post
    I already broke a nipple damn it, oh well live and learn. I still rather break a part of a hose rather then paying a shop 600 bucks to do this job.I have to do the water pump while I am at it. It sux because I need a long socket to get the coil pack off. Off to the store to get some tools.
  14. #14 Re: dumb question but?
    Palmdale
    Got the injectors off and notice ione of the gasket broken and one is missing. Also the hole where the injectors go are surrounded by dirt and oil. What's the best way to clean it?
  15. #15 Re: dumb question but?
    Palmdale
    Here is another pic of the injectors
  16. #16 Re: dumb question but?
    Palmdale
    This photo here the injector to the left is where the gasket is missing.
  17. #17 Re: dumb question but?
    your going to need new O rings for the injectors. and Q tips work good for cleaning out the holes there.
    it would have been best to have gunked/degreased the engine before starting the job to help clean things up, just clean all the parts you remove real good. dont clean the inside of the supercharger, just the outside. and clean your throttle body up real good while its off too.
  18. #18 Re: dumb question but?
    put the injectors back in before you attack that... you dont want that washing into your intake runners.
  19. #19 Re: dumb question but?
    Palmdale
    S.O.B kind of worried some might have gotten in there.well I. Could but the injectors back in and try to clean around the holes. **** I am afraid of screwing my car up. Thanks for the quick response
  20. #20 Re: dumb question but?
    yeah. thats what i'd do.
  1. Might be a dumb question, but...
    By SteveCZ28 in forum General Tech Discussion
    Last Post: 02-19-2011, 11:06 AM
  2. Dumb Question?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2011, 06:59 PM
  3. dumb question
    By Mike8410 in forum General Tech Discussion
    Last Post: 01-10-2011, 10:27 PM
  4. Hopefully Last dumb AC Question
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 12:48 PM
  5. Dumb question (Oil)
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2008, 12:10 PM
