Thread: Gapless rings
Results 1 to 6 of 6
  1. #1 Gapless rings
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Anyone here use total seal gapless rings on a 3800 rebuild? They have 3 sets available.
    Total Seal #'s for stock replacement type pistons
    MX6684- steel gapless top ring, conventional 2nd
    X6684- conventional steel top ring, gapless 2nd
    CR6684- ductile iron plasma moly top ring, conventional 2nd
    available in std., .020, .030, .040
    Anyone have any thoughts which would be better for a DD turbo 400+- WHP build? gapless top or second? I was going to just hone and rering/bearing my block before reassembling it. Possibly have the lower end balanced. (any point to doing that with all stock bottom end components or are they balanced at the factory?)
  2. #2 Re: Gapless rings
    St. Louis
    Not sure on the rings, but you will need a machine shop to line bore the bottom end or you will be on borrowed time on the new build. These motors are sensitive to this area and often come apart after something like this. Best bet would be to let the machine shop assemble the entire bottom end.
  3. #3 Re: Gapless rings
    Lorain, OH
    That was the plan. I'm either leaving it completely alone like so many ppl have told me to do, or sending it to a shop to have them do hone, linebore, balance and bearing replacement. Everyone says leave it alone, but it is hard for me to have a 150k mile motor out of the car and basically down to the rotating assy and not have it freshened up when I am putting substantially more HP through it.
  4. #4 Re: Gapless rings
  5. #5 Re: Gapless rings
    New gaskets, new fluids.
    It'll be just fine.
    Ohio
    ^ fo realz... In having the crank reground on mine. Checked, hot tanked, and reassembled.
  1. Does 1997 GTP SC have PCV o-rings ?
    By GTP in RTP in forum General Tech Discussion
    Last Post: 12-15-2011, 08:23 PM
  2. Injector 0-Rings
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-28-2010, 08:55 AM
  3. Hubcentric rings? used for wat?
    By keredwtf in forum Tires & Wheels
    Last Post: 07-14-2009, 02:57 PM
  4. Centering Rings on my new 18's
    By cboth686 in forum Tires & Wheels
    Last Post: 05-09-2009, 12:59 AM
  5. Wheel spacers/hub rings?
    By Iron Indian in forum Tires & Wheels
    Last Post: 04-08-2009, 09:53 PM
