Thread: newbie questions
Results 1 to 11 of 11
  1. #1 newbie questions
    40-15'30'' N 085-40'33'' W
    I am fairly new to the GTP world, but no means am i new to mechanics. i just picked up a 2000 GTP and i am getting ready to put a Triple Edge Performance transmission in it cause the origonal one took a crap. while i have the engin out i plan on fixing a few leaks. i am going to put a new oil pan gasket in and my lower intake manifold is leaking as well. my question is this, do the intake gasket kits from the local parts stores include the SC gasket and everything needed to do the job? i also noticed the little plastic elbow was leaking coolant. so that will get fixed as well. where is the best place to get the gaskets and everthing to do the job right? thanks in advance.
  2. #2 Re: newbie questions
    Sep 2011
    Southern Alberta, Canada
    I goto my local napa for alot, but i also use RockAuto Auto Parts
  3. #3 Re: newbie questions
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    get the coolant elbows from oreilys help section like $4 IIRC
    and the supercharger gasket is cheaper at autuzone but its under a different name i cant recall if someone could help i know it under intake then something
    if possible find a set of aluminum LIM Gaksets and dont forget to flush the oil at least a couple of times
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  4. #4 Re: newbie questions
    Ok. Maybe ill just get the gaskets from zzp cause the parts store couldnt tell me if the lower gaskets were alumInum, they couldnt tell me if the kit cam with a sc gasket and the valve cover gaskets were $50 themselves. I can get the better gaskets cheaper from zzp
  5. #5 Re: newbie questions
    Kansas
    Or Amazon... I got my set shipped overnight for $46.88.
  6. #6 Re: newbie questions
    sc gasket is the plenum gasket.
  7. #7 Re: newbie questions
    Ok. So if i buy an intake gasket set it should have the supercharger gasket cause its the same gasket at the plenum gasket on the naturally aspirated cars?
  8. #8 Re: newbie questions
    Nov 2010
    Maryville, MO
    thats what it was! i couldnt remember it was bothering me lol
    // 2005 Comp G
  9. #9 Re: newbie questions
    Ok maybe ill just go to the parts store and ask to look at the gasket kit and see if it has what i need.
  10. #10 Re: newbie questions
    Because pulling it up on the internet and looking at the picture isn't sufficient?
  11. #11 Re: newbie questions
    Well i looked on amazon like one of the guys suggested... The pics on amazon didnt show anything other than the LIM gaskets, i want to know im getting what i need. Not order something online and think im getting what i need only to find out i am short a gasket or two when i go to do the job. I dont like having to run back and forth to the parts store.. Makes for slow repairs and wasted fuel.
  1. Newbie Questions
    By Widowmaker in forum Introductions/Noob Questions
    Last Post: 11-18-2011, 07:23 PM
  2. newbie here sayn hey and had a few questions
    By jraypickett in forum Introductions/Noob Questions
    Last Post: 06-24-2010, 12:00 PM
  3. Newbie with 07 GT questions
    By davidd in forum Introductions/Noob Questions
    Last Post: 09-29-2009, 03:39 PM
  4. Newbie Questions
    By b4rigger in forum General Tech Discussion
    Last Post: 08-16-2009, 04:03 PM
  5. newbie with questions
    By southerndawg09 in forum Introductions/Noob Questions
    Last Post: 08-06-2009, 11:16 AM
