Thread: Any guesses on what I will dyno with S2 Intercooler?
Results 1 to 20 of 24
  1. #1 Any guesses on what I will dyno with S2 Intercooler?
    SE Level Member Mad Max's Avatar
    Jan 2012
    Kentucky
    2005 GTP. I'm installing Stage 2 I/C and ZZP PCM with a scanguage to pave the way for future mods. Just out of curiosity, if my car dynoes around 215whp stock, what can I expect after this, ZZP advertises it as a 50hp bolt on, but I'm sure that is a tuned car and not stock, so maybe half that for an otherwise stock car? Maybe dyno 230-240fwhp?
    Ohio
    Don't get a zzp pcm.. Get a tuner yourself or find someone to custom tune it
  3. #3 Re: Any guesses on what I will dyno with S2 Intercooler?
    It shouldn't need much of a tune anyways.
    Regardless, if you're not changing the pulley you won't see much gain if any.
    Possibly a loss as the core is a restriction.
  4. #4 Re: Any guesses on what I will dyno with S2 Intercooler?
    S2IC with 3.4", headers, PCM tune...
    250 FWHP?
  5. #5 Re: Any guesses on what I will dyno with S2 Intercooler?
    Banned
    CT
    Quote Originally Posted by Mad Max View Post
    Putting an intercooler on an otherwise stock engine isn't really going to help you out that much. You'll probably gain 10-15whp if you don't touch anything else. You would be better off doing headers and a 3.6'' with a custom tune. IMO people should skip intercooling until after they've done heads/cam or at the very least a cam. The engine's VE blows and flow should be addressed before anything else.
    Depending on the dyno you're probably closer to 200whp. The issue is there's all different types of dynos and correction factors. The most widely accepted standard of dyno and CF is a dynojet and SAE correction. The only issue there is that is usually the combo that reads the lowest.
    As for a guess... your car with an IC and ZZP PCM... 215whp, SAE on a dynojet.
  6. #6 Re: Any guesses on what I will dyno with S2 Intercooler?
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Quote Originally Posted by SnowFlake View Post
    Why not a 3.0"? I mean, if hes using a full S2IC then he should take advantage of that extra torque from the 3.0". You should be good with a 3.0", but me personally I would at least throw some headers on(along with the lil other supporting mods) to assure you'll be KR free(hopefully)
    I also agree with taking further advantage of the full I/C by installing a CAMSHAFT. But at the end of the day, a full I/C, PCM tune, TB ported a lil, headers or at least 3" DP w/u-bend delete, 180*stat, CAI, 1-2 heat range colder plugs, with that 3.0" pulley, I think you'll be pulling much better than u did with the previous setup.....
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  7. #7 Re: Any guesses on what I will dyno with S2 Intercooler?
    Minnesota
    Quote Originally Posted by Dee23 View Post
    LOL 9 months later.
  8. #8 Re: Any guesses on what I will dyno with S2 Intercooler?
    Im intercooled with a stock cam/heads....
    anyway... youre not gonna see much of a gain unless you drop pulleys to take advantage of the ICs purpose...
    what other mods will you have with it?
  9. #9 Re: Any guesses on what I will dyno with S2 Intercooler?
    Jan 2012
    Kentucky
    Well, I wasn't too concerned about the gains of the IC by itself, as I said, it will be paving the way for future mods. Quite frankly I don't trust most shops to dyno tune yet, I haven't found a good shop I can trust, I have had some bad experiences with my mustang and people that didn't know what they were doing...except how to ring up a huge bill for a bunch of nothing.
    Anyone in the north central KY area (Louisville, Lexington) know a good shop that has experience in W body's? I'm pretty new to the area.
  10. #10 Re: Any guesses on what I will dyno with S2 Intercooler?
    You could go to prj in indianapolis.
  11. #11 Re: Any guesses on what I will dyno with S2 Intercooler?
    SE Level Member Myprixxx's Avatar
    Apr 2008
    Decatur, IL
    If you also have a scan gauge you will be alright running a box tune until you get more mods and want to splurge for a legit tune.. Just watch your KR, I went with a box tune on my 3.4 setup and just watched it closely. Now that I have moved on I will be doing only tunes that are setup for my application
    i knew this guy wasn't b/sing.
    michigan people have better stuff to do, like finding jobs or avoiding robbery.
    quoted from noreasonwhyy
    GenV, Full sized I/C, HAI, 3.0 MPS, N* TB
  12. #12 Re: Any guesses on what I will dyno with S2 Intercooler?
    Jul 2012
    North Philly
    LOL, 9 months later and theres still 3800 drivers out there looking for this very same info. I mean, either we make new threads on every single topic or just respond to the originals no matter how old....LOL
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Most noobs don't search for their answer anyway ...
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  14. #14 Re: Any guesses on what I will dyno with S2 Intercooler?
  15. #15 Re: Any guesses on what I will dyno with S2 Intercooler?
    Heads over ic alll day both should have headers any ways so heads headers smaller pulley and tune
    Heads over ic = less headaches lol ask around.........
  16. #16 Re: Any guesses on what I will dyno with S2 Intercooler?
    performance wise maybe... the IC process is half the price, an easier mod and is not a hassle if done right...
  17. #17 Re: Any guesses on what I will dyno with S2 Intercooler?
    Quote Originally Posted by gtpsleeper View Post
    WBStore has cnc heads for $999 and good luck doing an ic for less.
    Heads headers pulley and tune
    Then e85 and roller rocker all with out tearing the engine apart for a cam no ic pump lines and core to deal with not to mention heads will help kr and flow.
    Anyone know what a heads header rocker car with gen3 and slicks runs? Iirc someone was in the 12s not sure if e85 or not.
  18. #18 Re: Any guesses on what I will dyno with S2 Intercooler?
    $800 brand new and installed (+ the antifreeze of course) and you can piece together a good used one for about ~500 now and used head jobs tend to keep their value if sold used... and I didn have to drain any fluids or "tear the engine apart" other than lifting the SC off. Also, last I checked ICers help with KR too....
    Not trying to argue which mod is better or worse Im just saying your making the IC out to be this horrible comparison to heads in almost every aspect when its not...
    I dont know what guy your referring to but for the sake of argument, I know my stock heads/cam setup with an IC runs 12s as well...
  19. #19 Re: Any guesses on what I will dyno with S2 Intercooler?
    Jul 2012
    North Philly
    Yup, we all were NOOBS at one point seeking for answers......
  20. #20 Re: Any guesses on what I will dyno with S2 Intercooler?
    Minnesota
    So many variables. I would start with your largest pulley and keep adding timing until you get to 20* then pulley down. A smaller pulley means nothing if you are running 10* of timing.
  1. What's Next! Dyno or Not!
    By foursixer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2011, 02:11 AM
  2. You get four guesses!
    By Dthreap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-08-2011, 05:42 PM
  3. Dyno today.....any guesses
    By 2003 SSEi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2010, 10:41 AM
  4. zzp intercooler vs wbody store intercooler ?
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-04-2010, 02:40 AM
  5. Dyno #'s
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 02-28-2009, 03:56 AM
