Thread: Name that sensor
Results 1 to 12 of 12
  1. #1 Name that sensor. PLEASE DELETE
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    Im trying to figure out what this sensor is. I know what the one on the right is but have no idea what the one on the left is. It has a wiring plug going into the side but that's it has a nipple on the bottom for vacuum line maybe but nothing is connected to it.
    Dec 2011
    Grand rapids Mi
  3. #3 Re: Name that sensor.
    id like to know aswell, they look the exact same, like 2 map sensor, but idk.
  4. #4 Re: Name that sensor.
    Ohio
    can you get any numbers off of them?
    Dec 2011
    Grand rapids Mi
    Nope can't see any numbers without pulling off the whole bracket
  6. #6 Name that sensor
    Dec 2011
    Grand rapids Mi
    http://i1062.photobucket.com/albums/...msel/photo.jpg
    Dec 2011
    Grand rapids Mi
    I accidentally put this in NA section instead of supercharged.
  8. #8 Re: Name that sensor
    Florida
    Map sensors looks like. and you only need one thread not two
    Dec 2011
    Grand rapids Mi
    Yeah I put it in the wrong section figured I would get better responses if it were in the right section. So there's two map sensors?
  10. #10 Re: Name that sensor
    Florida
    cant tell from the pic, but my guess is one is connected to the vac line and the other is open to the air. so one reads the MAP value and the other reads atm pressure.
    Dec 2011
    Grand rapids Mi
    That makes sense. Thanks
  12. #12 Re: Name that sensor
  1. thermostat temp sensor and interior air temp sensor failure?
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-26-2011, 10:07 PM
  2. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  3. Best way to change O2 sensor/ECT sensor?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 11-23-2010, 09:36 AM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
