So I'm installing a zzp fuel pump, and something doesn't match up. They send you 2 hoses, one black one clear bendy plastic (check the picture - ZZP350 in Tank Fuel Pump # ) Which one do I use? I tried and cannot for the life of me get the plastic hose on the fitting on the underside of the top of the canister. The factory one looks similar to the bendy plastic hose but not identical. Also The plug they send that goes into the pump itself is different (also see picture) Where do I splice it in? And how? It's inside the canister so I'd really like to avoid blowing my car up. As always any help is massively appreciated.
