I can't or won't give you advice on mechanical stuff but I will say this - make sure to set things in order or in a way that you know where they go back together (labels would not be a bad idea) and if possible take a bunch of pictures during your disassembly to help yourself with the re-assembly. Some of the numerous bolt even though they look the same and go into the supercharger for example go into different holes because of length so before you toss them in a pile make note of which go where. It is not hard to do, but can be a little daunting when/if you have a gazillion pieces out and not sure how they go back in. If you are handy and mechanically inclined, 1 day should be more than enough though I'd guess. If you have not already watched the LIM video by DuBob in the how to section on here that is 33 minutes I would say to do that for sure first also. People on here are great help too, before during and after you do things. Posting pictures and questions together will usually get the quickest and most accurate help if you need it. Good luck!
