Thread: Bought an LS1 TB kit need to figure out how to get cruise control to work.
Results 1 to 17 of 17
  1. #1 Bought an LS1 TB kit need to figure out how to get cruise control to work.
    GTP Level Member buickman104's Avatar
    NYC
    I bought an ls1 tb kit. The catch is that it doesn't have cruise control. Anybody know where I can weld or machine a tab on the tb to make cruise control work again?
    Also guys with ls1 throttle bodies with working cruise control can you post pics of your set ups to give me some ideas?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    Omaha, NE
    If the mods in your signature are current, you don't need a bigger TB.
    If you want to install it anyway... you will need a new bracket for throttle and cruise.
  3. #3 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    NYC
    I got it so it would match the inlet on my gen 5 supercharger. I was thinking that the stock throttlebody would be causing a restriction.
    Know which vendor sells the bracket? Can I use one made for a north star tb?
  4. #4 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    Omaha, NE
    Losing cruise is generally expected when going to the LS1 TB. Some people say you can make your own (I lost the thread from here I was looking at earlier)
    Others say that some LS1 tb's have cruise and others don't.
    LS1 throttle body - 3800Pro.com Forum
    You may have been better off getting a N*, since those do come with cruise.
  5. #5 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    Bastard Reptile's Avatar
    Kansas City, MO
    If it's got the tab on the side, then it's got cruise. You need to grind off the flattened part of the throttle shaft that holds that little bracket on, flip it 180* and tack weld it back on. It's less than a 5 minute job. Modify your stock cable bracket to mount on your new setup, and you're done.
  6. #6 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    NYC
    Here are some pics of the throttlebody.
    Doesn't look like there is a tab for cruise control. Anyone have any ideas of a way to mod this for it to be able to gain Cruise control?
  7. #7 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    You don't have a tab. You need a tab for cruise.
    Answer me this question. Why does a guy who lives in NYC need cruise control?
  8. #8 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    Mullet Member Wotgtp's Avatar
    Connecticut
    The TB that blue sent me has the part that reptile is talking about. I'll see if I can post up a pic.
  9. #9 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    NYC
    Thanks Wotgtp. With a picture I can get some idea of how to modify it to regain cruise.
    Also Bill, I love getting the heck out of this city!!! I mainly need cruise control on weekends.
  10. #10 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
  11. #11 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    Connecticut
    Buickman if you need more pics I can email them to you, otherwise I'll post them up late tonight when I get home from,work.
  12. #12 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    NYC
    Yes please. If you could get a couple of closer pics I would really appreciate it.
  13. #13 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    Kansas City, MO
    This is about the best picture I can find of the tab, and how it's oriented on the linkage.
  14. #14 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    Ohio
    look at this guy ^^ lol
    even though he prefers moar katz in a trailer :P
  15. #15 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    Kansas City, MO
    Hey, at least I've got a sense of humor, right?
  16. #16 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    Ohio
    yes, yes you do lol
  17. #17 Re: Bought an LS1 TB kit need to figure out how to get cruise control to work.
    NYC
    Well, the plan is to cut the cruise control tab out of the L67 throttle body and weld it on to my LS1 TB. I'll post pictures once its done.
  1. Cruise control does not work, suggestions??
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2011, 06:49 PM
  2. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  3. Cruise Control Help !!!
    By avenger33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2010, 07:33 PM
  4. 2006 GPGT, cruise control doesn't work.
    By acammer in forum General Tech Discussion
    Last Post: 11-23-2010, 07:56 AM
  5. Cruise control and AC won't work
    By ala17 in forum General Tech Discussion
    Last Post: 06-28-2009, 11:47 PM
