Quote Originally Posted by 03GTP38k View Post
Thanks Matt5512 I will be checking the wiring and the harness tomorrow. Have you ever heard of having to replace the entire harness? Just curious as to how difficult it would be to replace
If you are talking about just the harness that runs to the cam and crank sensors, you could swap that out in a few minutes. Everything else, you should be able to isolate with the website I showed you. Something simple probably. Keep at it.
