Thread: P0303 missfire
Results 1 to 11 of 11
  1. #1 P0303 missfire
    SE Level Member BigGeorgesGTP's Avatar
    Middle River, Maryland, United States
    ok so i got my car it was in bad shape put NEW.... plug/wires/coil packs/crank posion sensor/ICM/fuel injector and still i get a cylender 3 missfire.. thats the only code and its really bad at idle i just wanna get it running right there is no motor knock or tapping or anything any idea's please help
  2. #2 Re: P0303 missfire
    compression test it yet?
  3. #3 Re: P0303 missfire
    no im doing that tomorrow... is there anything i should be looking for???
  4. #4 Re: P0303 missfire
    you want all cylinders to be around the same compression and none no lower than 20% less than the average.
  5. #5 Re: P0303 missfire
    what is the average?
  6. #6 Re: P0303 missfire
    well like say you have:
    120
    118
    114
    124
    121
    and 80
    that 80 would be more than 20% less than the average.
    Kinda get it, I'm not the best at explaining
  7. #7 Re: P0303 missfire
    Wichita
    It could be a vacuum leak. jus sayin....
  8. #8 Re: P0303 missfire
    great... im great with cars its my job but im new to the gtp thing lol
  9. #9 Re: P0303 missfire
    St. Louis
    Check all your vac lines, especially the one T under the SC snout as it likes to rot and crack.
    What brand/type of plugs did you install? Gap? These motors do not like platinum plugs and will often have issue with them even when brand new.
    Which cyl. got the replacement injector? If it's #3 then it may be worth your while to verify that it is firing properly. IIRC Bill said somewhere that you could bend the tabs on a 194 bulb out and stick the bulb into the injector harness connection and if it lights then it is getting power to fire the injector.
    Could be a wiring issue. Also check all your grounds. And since you replace the ICM be sure that the harness to it is all the way in and tight.
  10. #10 Re: P0303 missfire
    I've seen an ICM cause a single cylinder misfire before.
    Is the plug fouling or any indication that maybe you have a chipped piston? (compression test may show this) I doubt it's a vaccum leak. Three being the middle cylinder it would have to be a bad injector o-ring and you mention a new injector. However being the middle cylinder, it gets warmer than the outter two and has a higher probability of chipping a piston.
    I would check compression and maybe borrow a borescope if possible to look in there. Other than that, swap on a spare ICM (or a buddies) and see if the issue goes away.
  11. #11 Re: P0303 missfire
    Wichita
    ^^^This.
  1. missfire cyl 6
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2011, 01:53 AM
  2. Need help finding out what i need to fix! P0303 and P0171 codes
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2010, 08:45 PM
  3. Bad idle and RPM issues not to forget codes P0303, P0341, AND P0300
    By jessiinicole in forum Off Topic Discussion
    Last Post: 03-08-2010, 02:27 PM
  4. Code P0303, and p0300
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 09:08 AM
  5. P0303 - Cylinder #3 Misife ...
    By 98GP*GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2008, 01:23 PM
