Thread: 1997 GTP check engine light flashes when i hit the gas and bogs down help?! pleaseeee
Results 1 to 10 of 10
  1. #1 1997 GTP check engine light flashes when i hit the gas and bogs down help?! pleaseeee
    Apr 2011
    magnolia
    i have 97 gtp and when i push on the gas too take off it shakes and bogs down bad. it still gets up and goes but definately lagging. kinda hard too explain. the check engine light also flashes when this happens which is everytime i put the pedal down too pick up speed. this is a very well maintained gtp and i just have no clue where too start i put new plugs in recently. oh and idk if it matters but i also put in new fuel filter also. just looking for some help. all of my cars have been grnad prixs love them and never had major issues til now. any help or suggestions? i heard maybe the wires would do that? idk please help!
  2. #2 Re: 1997 GTP check engine light flashes when i hit the gas and bogs down help?! pleas
    Omaha, NE
  3. #3 Re: 1997 GTP check engine light flashes when i hit the gas and bogs down help?! pleas
    Apr 2011
    magnolia
    well in that thread everyones talking about when they are going fast. mine does it when i put my foot down half way i need too change the wires anyway i figure. but i just cant believe one plug wire would do soo much. flashing light means misfire but are there other things that could cause this issue besides plug wires? the coil packs are newer and i know those very rarely go bad. clogged cat maybe?
  4. #4 Re: 1997 GTP check engine light flashes when i hit the gas and bogs down help?! pleas
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    your engine is misfiring
  5. #5 Re: 1997 GTP check engine light flashes when i hit the gas and bogs down help?! pleas
    Oct 2011
    Michigan
    it could be your spark plugs your wire you coil packs or your fuel injectors
  6. #6 Re: 1997 GTP check engine light flashes when i hit the gas and bogs down help?! pleas
    Flashing light technically does not mean misfire. It means a possible catalytic damaging condition. Most of the time, it's a misfire. Could be a few other things, but most of us having run across them.
  7. #7 Re: 1997 GTP check engine light flashes when i hit the gas and bogs down help?! pleas
    St. Louis
    Get the car scanned for codes and post what the codes are. This will help us help you figure it out. I just went through this on my 00 GT and found a cracked coil which then took the ICM with it. The only code I had was a P0300 (Random Multiple Misfire).
  8. #8 Re: 1997 GTP check engine light flashes when i hit the gas and bogs down help?! pleas
    Apr 2011
    magnolia
    I havent had a chance rececently too get it checked cuz i work 12 hrs a day and have two kids and a wife and time is slim. The code reader said both o2 sensors before and after cat were bad and a misfire in cylinder number 4 thats all.
  9. #9 Re: 1997 GTP check engine light flashes when i hit the gas and bogs down help?! pleas
    Sep 2011
    MI
    "a misfire in cylinder number 4"
    probably a good place to start eh?
  10. #10 Re: 1997 GTP check engine light flashes when i hit the gas and bogs down help?! pleas
    St. Louis
    Check to see if the plug wire for cyl. 4 is touching the O2 sensor back there. If so, then it may have fried the plug wire.
  1. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  2. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  3. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  4. Pours blue smoke, wont idle, check engine light flashes!?
    By 1fastz71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2010, 09:13 PM
  5. Right signal light flashes fast, left signal flashes normal speed?
    By nboylie in forum General Tech Discussion
    Last Post: 11-23-2009, 06:38 PM
