Thread: 2002 GTP cylinder 4 misfire
Results 1 to 15 of 15
  1. #1 2002 GTP cylinder 4 misfire
    Dec 2011
    CHICAGO
    I just bought tonight a 2002 GTP, really clean car but high miles (150,000) all highway. It is misfiring on cylinder #4 Problem stays on #4 when swapping plugs, wires, coil. No intermix in oil or coolant. Car will drive anywhere, just has a miss. It is blowing oil out of the dip stick tube when driving. Guy i bought it from has it has a piston out of it. I don't this so, but what do you guys think? What tests should i do next?
    Thanks for any help
    Rich
  2. #2 Re: 2002 GTP cylinder 4 misfire
    Grand Rapids, MI
    you tried switching the fuel injector on cylinder 4 to another one and see if it moves??
    and for the oil, perhaps PCV valve?
  3. #3 Re: 2002 GTP cylinder 4 misfire
    Omaha, NE
    That's not really what's considered "high miles", insurance averages are around 14k per year.
    If it's not in the Plug, Wire, or Coil, its either an injector or Ignition control module. Possibly in a rare case the fuel rail could have something plugging that cylinder.
    Oil blowing out the tube is a pcv issue.
    The only way to know if it's a piston is to do a borescope or tear the top end off.
  4. #4 Re: 2002 GTP cylinder 4 misfire
    Dec 2011
    CHICAGO
    do these cars have problems with pistons?
  5. #5 Re: 2002 GTP cylinder 4 misfire
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    You can do a compression test, or better yet, a cylinder leak down test. The leak down test would be a good one if you have access to an air compressor.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  6. #6 Re: 2002 GTP cylinder 4 misfire
    Omaha, NE
    Not unless you fail at modding. Is your car bone stock?
  7. #7 Re: 2002 GTP cylinder 4 misfire
    Dec 2011
    CHICAGO
    The guy said the oil blowing out the tube started with the misfire.
    Could a rocker stud have pulled out of the head. I heard of that
  8. #8 Re: 2002 GTP cylinder 4 misfire
    Dec 2011
    CHICAGO
    100% stock
  9. #9 Re: 2002 GTP cylinder 4 misfire
    Omaha, NE
    If a rocker stud came out, the rocker would be ticking.
    Do you have a check engine light on? If so what are the codes it's on for?
  10. #10 Re: 2002 GTP cylinder 4 misfire
    Dec 2011
    CHICAGO
    p0304
  11. #11 Re: 2002 GTP cylinder 4 misfire
    Dec 2011
    CHICAGO
    could it be a problem with a valve in the head? Seems like the crankcase is being pressurized blowing the oil out. I think its all related
  12. #12 Re: 2002 GTP cylinder 4 misfire
    Omaha, NE
  13. #13 Re: 2002 GTP cylinder 4 misfire
    Ontario, Canada
    Do a cylinder leak down test like I stated above, to help narrow down the possibilities. It will tell you if you have a piston issue. I'm thinking you have a hole in the piston or the ring lands are busted up (know issue) allowing combustion gas's and pressures to enter the crank case and pressurize the crankcase. A cylinder leak down test, or even a boroscope will tell a better tale.
    Jay
  14. #14 Re: 2002 GTP cylinder 4 misfire
    Dec 2011
    CHICAGO
    OK, i'll check it out and let you guys know what i find. Thanks for the help
  15. #15 Re: 2002 GTP cylinder 4 misfire
    Dec 2011
    CHICAGO
    Well its hurt!
    35psi on the compression test on cylinder #4
    100% on the leak down
  1. Cylinder #2 misfire
    By EJOUIE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:38 PM
  2. Cylinder #3 misfire
    By Newby101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2011, 03:02 PM
  3. Misfire in Cylinder 6
    By Porach in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 02:19 AM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
