Thread: Pulley Swap MPG's
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 Pulley Swap MPG's
    SE Level Member MyPrixGT06's Avatar
    Weirton, WV
    I couldn't find the search bar on this forum anymore so I hope this isnt a repost, which I'm betting it is. I am about to down size my pulley from stock to, I think I want a 3.4. I have a 195 tstat and an intake. I would get colder plugs and probably eventually a ubend delete and a pmc from zz. After that I was wondering what range of mpg to expect for average driving.
  2. #2 Re: Pulley swop MPG
    Charles City, IA
    0 because you will more than likely blow up the car.
    SMGPFC Two Nipple General
  3. #3 Re: Pulley swop MPG
    the same as you make now, a little less since youll be in the throttle more.
  4. #4 Re: Pulley swop MPG
    needs more mods that than to drop to a 3.4.
    and if you're 04+ even more mods.
    Do mods first, then drop to a 3.6 is you're a 04+ car.
  5. #5 Re: Pulley swop MPG
    Ohio
    read this http://www.grandprixforums.net/safely-modding-your-3800-powered-car-17482.html
    that is all.. dont think about dropping pulleys until youve read it 11 times...then read it more
  6. #6 Re: Pulley swop MPG
    Out West
    You already have knock stock.
    Don't touch the plugs or tstat.
    Do get an Intake, Headers, Leave the pulley alone though. Your car will feel faster because it's no longer knocking.
    Whine with your Cheese?
  7. #7 Re: Pulley swop MPG
  8. #8 Re: Pulley swop MPG
    Weirton, WV
    I've read that post many times and from what it's saying on on my way to 3.5 or 3.4. I Might just take five fingers advice and do the mods I was thinking of then just drop to a 3.6. Yes it is a 04+. Why are the gen iii unable to take as much boost?
    2006 Pontiac Grand Prix GT-
    180 tstat and intake.
  9. #9 Re: Pulley swop MPG
    Out West
    Quote Originally Posted by MyPrixGT06 View Post
    You have knock (predetonation) stock.
    Headers, Intake, leave stock pulley, and if you're not knocking, THEN a 3.6
  10. #10 Re: Pulley swop MPG
    Weirton, WV
    ZZ stage 2 kit comes with PCM, downpipe, plugs, Tstat, CAI, and 3.6 pulley. So why are some of you saying I need to do more? Headers would be great, but from what I've read not absolutely needed. Might still go with headers, not sure yet.
  11. #11 Re: Pulley swop MPG
    Out West
    1. Don't buy "Stage" kits.
    2. ZZP is the same company that claims you can run a 3.5 pulley totally stock on a 97-03. -- Take what they say with a pound of salt.
    I think a group of owners who have modded before and therefore have and share real world results best the knowledge of a vendor.
  12. #12 Re: Pulley swop MPG
    the blower is more efficient so you make more boost on the same pulley as the 97-03 folks.
  13. #13 Re: Pulley swop MPG
    Ohio
    noooo from what its saying, youre not even close. how bout you drop to a 3.79999?
  14. #14 Re: Pulley swop MPG
    Weirton, WV
    I quess the 04+ having more boost makes sence, because we have different superchargers, correct? How do you know when you not knocking? From what I understand we have knock censors, why don't they stop this or let us know? Do I need to go straight to headers? I was looking at Pacesetter Headers from zz with pro kit and looks like it will bolt to stock and delete the cat. If my state doesn't require a cat, is that a good set up?
  15. #15 Re: Pulley swop MPG
    Out West
    Yes we do but knock sensors only reduce timing advance AFTER knock has occured.
    Go straight to headers.
  16. #16 Re: Pulley swop MPG
    Weirton, WV
    I'm not saying you are wrong I was just wondering. I am thankful for the advice. So are the headers i said good and do they bolt right on? Which headers do you have and where from?
  17. #17 Re: Pulley swop MPG
    Out West
    I have the Ebay SLP/SSAC knockoffs, they work just fine.
    I've heard the Pacesetters/OBX are a pain to get in. Hopefully someone here who has exp with them will chime in.
    And yes they all bolt right in.
  18. #18 Re: Pulley swop MPG
    May 2011
    ohio
    most people will tell you to get speed daddy headers because there cheap and easy to install might want to check them out
    grand prix speed daddy headers | eBay
  19. #19 Re: Pulley swop MPG
    Weirton, WV
    Looking on eBay there are headers costing around the same as a downpipe. If others agree something like this will work fine that's the way I wanna go.
  20. #20 Re: Pulley swop MPG
    GT Level Member outonthetiles's Avatar
    Dec 2011
    Herkimer, NY
    A 195* tstat is not a mod.
    Swop is spelled swap.
    An aeroforce gauge or something similar would tell you if you're knocking.
  1. top swap pulley ?
    By kevins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2011, 05:43 AM
  2. 3.8/3.4 pulley swap
    By NewBoost1997 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2010, 02:27 PM
  3. Supercharger Pulley Swap
    By littlerobinson75 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 08:53 AM
  4. pulley swap question
    By jersey jok3r in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2009, 12:04 PM
