Quote Originally Posted by 00grandprixgtp View Post
if you take the bottom hose off the bbv and put a bolt in it to block it off it will only go half boost that should keep it prob around 6 psi or 8 with a 3.2 pulley at full throttle just have to bypass the computer control valve also if you take that hose off it will kill the speed limiter in D only least it does on my 2000 gtp but it 3rd it only goes 105 and hits the limiter
The stock limiter in the gtp's is 126 iirc
