Quote Originally Posted by L KELLS View Post
i Have a buddy with a 2000 GTP Thats Mildly moded. I scanned his car and it had the p0102 code. Normally we all think bad MAF sensor. Right? Went to the local yard and picked up a few for little to nothing..... Replaced it, cleared the code, and not even 10mins each time same code, same result. We then went to buy one new from the parts store (OUCH) and as sure as sh*t stinks..... Same code pops up. I checked the wiring and connector and the MAF and it seems to be ok. The scanner that i have allows me to view each sensor voltage outputs and every other sensor that i can read is responding except the MAF. The car even have all the "bad maf" symptoms, like running sluggish at idle, stalling while at a stop light, hard starts, even running a little better when i unplug the maf. Im wrecking my brain here guys Please help!!!!
Check the wires at the maf connector. Key on but engine off. Check the signal wire and see if you're close to 5v (yellow wire). If you're good, check the ignition wire it should show about battery voltage (pink wire). Check ground wire, it needs to ground (black/wht wire). You could connect a 12v test light between the ignition feed and ground wires to see if the light lights.
