Thread: abs/traction control
Results 1 to 7 of 7
  1. #1 abs/traction control
    Jun 2010
    ohio
    I have a 2000 pontiac grand prix gtp and my abs light came on and shut back off a couple times well now its always on and it shut my traction control off too, what could that be? a sensor or something else maybe?
  2. #2 Re: abs/traction control
    Oct 2011
    Toledo, OH
    It's downright amazing that this has come up half a dozen times in the past two weeks and people still ask about it.
    You probably have an hub bearing that needs replacing or a wheel speed sensor gone bad, which requires a hub replacement.
    Worst case is the ECBM (abs module)
    7"
  3. #3 Re: abs/traction control
    Aug 2011
    'Merica
    I had this happen to my 03 a few years ago. i would check all of the wires before dropping money into a new hub. The wires on mine were brittle and broke causing the problem that you are having. Take the front wheels off and the find the sensor in each hub and follow the wires to see if either side is broke. if the wires are broke that is an easy fix. Call your local GM dealer and tell them what you need. I think it cost me around $60 for the passanger side wiring harness. All you need to do is splice the new wires together where the wires were broke and shrink wrap the splice junction. The harness came with shrink wrap. If the problem is not this then it probably the above statement. If i had the garage i would take some pics. I am sure sombeody in here could explain it better than i can. Clear as mud, right?
  4. #4 Re: abs/traction control
    Donating Users
    Aug 2011
    Lowell, IN
    Go to the brakes section of this forum. There are a few of us running this problem down right now. You may gain some wisdom from those threads. I know I have. That is why I have a EBTCM sittting next to me at work right now.
    '99 GTP coupe, bone stock because I have enough troubles already.
  5. #5 Re: abs/traction control
    Pennsylvania
    Quote Originally Posted by industrialfish View Post
    You mean best case. EBCM is way easier to do than a bearing and close in price.
  6. #6 Re: abs/traction control
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Quote Originally Posted by SlowNA06 View Post
    Close in price? My EBCM is out, dealership wants 1k for a new one. F that.
    Rock auto was 500 or 600 I believe for a new one. A used one would be. Cheaper of course or getting rebuilt (if possible). And an assembly is 80-200.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180ยบ Thermostat, Flipped Dog Bones
  7. #7 Re: abs/traction control
    Pennsylvania
    Quote Originally Posted by fri3dchick3n View Post
    Rebuild > New
    They're faulty from the factory, so a new one is not a fix. Rebuilders solder in extra parts to make the EBCM bulletproof. So, yeah, you're looking at $175 tops.
  1. Traction Control ON/OFF
    By JDrach in forum General Tech Discussion
    Last Post: 11-07-2011, 12:03 AM
  2. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  3. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  4. Traction Control
    By Dewey1964 in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2010, 11:06 PM
  5. traction control?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-27-2009, 08:56 PM
