Thread: How much HP should I expect?
Results 1 to 20 of 38
  1. #1 How much HP should I expect?
    Ontario
    This week I am installing an XP Cam with 105 springs into my L26 as well as a GenV top swap with a 3.4 pulley and headers. What HP numbers should I expect to the wheels? I am getting an in-car tune from Overkill Motorsports too. I am guessing around 325hp to the crank after its tuned? Maybe run a 3.25 after I get 42.5 injectors? maybe 340hp to the crank?
    Do you think its safe to run a 3.4 pulley on that setup without getting it tuned? I have a MPS to install as well, and a 3.5 or 3.6 pulley. I also have an aeroforce I can't figure out how to get it to work.
    Also, I have a stock torque converter from an 06 Grand Prix, would I benefit anything putting that in?
    I have a 04 CompG.
  2. #2 Re: How much HP should I expect?
    Hagerstown,Md
    300whp. You will need to tune it. 3.4 is pushing the injectors aswell on a l26 build.
  3. #3 Re: How much HP should I expect?
    42.5 delphi or lucas injectors are terrible.
    3.4 sounds right, maybe larger.
    But only one way to tell.
    260-280 WHP sounds fair to me.
    Heads being touched at all?
    If they're off, its worth the time.
  4. #4 Re: How much HP should I expect?
    Omaha, NE
    300whp
    Now take it to a dyno and find out instead of playing "what if"
  5. #5 Re: How much HP should I expect?
    Out West
    280whp
    Whine with your Cheese?
    Stock+Self Tuned. Going for low 14's everyday.
  6. #6 Re: How much HP should I expect?
    utah
    So...what happened to the L32 from the compg....
  7. #7 Re: How much HP should I expect?
    Because Wet Leaves Hippo Machine's Avatar
    Jun 2011
    Detroit, MI
    Wow, that'll feel like a whole different car when you're done
    iLoveSpade
  8. #8 Re: How much HP should I expect?
    utah
    I'm hoping on an xp setup you make more then me.......
  9. #9 Re: How much HP should I expect?
    Ontario
    I was thinking the 3.4 will be a bit much as well, it wont be for another month I'll get injectors, but I'll run the biggest pulley I have for my MPS until I can get a tune and keep my eye on the KR(this time around).
    I chipped a piston. I ran SR Rockers, catless headers and a 3.4 pulley with an in-car tune from Overkill Motorsports without any knock on 91 octane. Lasted about 15,000km(8,000 miles?) and BAM, oil squirted out of the dip stick so I pulled the front head and sure enough my number 3 piston was chipped. prior to this, about 7,000km before I has misfire issues so I changed the plugs and wires, my number 3 spark plug was broke off, but I figured it blew out the exhaust somewhere and it ran awesome after I installed auto lite 104s.
    So I've been without the car since mid october(my daily driver) and I learned one thing! Keep an eye on my aeroforce!
  10. #10 Re: How much HP should I expect?
    and will likes rich.
    11.0:1 afr.
    so its kinda scary you managed that so quickly.
  11. #11 Re: How much HP should I expect?
    utah
    Scary but possible. Glad you learned from it though. Again id expect your xp setup to make more then my rocker setup.
  12. #12 Re: How much HP should I expect?
    Ontario
    I forgot to mention I have about 190,000 miles on the car. I was driving the car about 1500 miles a week for the past 3 months before this happened lol.
  13. #13 Re: How much HP should I expect?
    Banned
    CT
    Quote Originally Posted by boostedcompg View Post
    Got a scan of your dyno sheet? I'm interested to see that 290whp.
  14. #14 Re: How much HP should I expect?
    utah
    Sure do. Its posted with my dyno vid as well
  15. #15 Re: How much HP should I expect?
    Banned
    CT
    Where can I find this dyno sheet and video?
  16. #16 Re: How much HP should I expect?
    utah
    search?......youtube?
  17. #17 Re: How much HP should I expect?
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    You should expect disappointment.
    1998 GTP : XP Cam, 3.2 Pulley, Supporting Mods<Sold>
    2001 Formula M6 : Shhhh
    2001 SSEi : New DD, Bone Stock for now
  18. #18 Re: How much HP should I expect?
    Banned
    CT
    Couldn't you just post a nice link and picture?
  19. #19 Re: How much HP should I expect?
    GT Level Member aligater's Avatar
    london ontario canada
    bring the aeroforce by and I'll show you what you gotta do.
    The 06 torque conv will be one step up from stock, very small step.
  20. #20 Re: How much HP should I expect?
    Kansas
    Yeah wtf.... my head is hurting a little. 04 Comp G + L26 + Gen V topswap????? fml.
  1. how much to expect....
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-28-2009, 04:39 PM
  2. how much to expect
    By IrishNation24 in forum General Tech Discussion
    Last Post: 10-04-2009, 08:47 PM
  3. You'd Never Expect It...
    By Panzer4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-31-2009, 02:32 AM
  4. 98 GTP- What to Expect?
    By SMM2469 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 10:19 PM
  5. How long should I expect my car to last?
    By scoobyydooooooo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2008, 12:11 PM
