Turbo is a lot of money all at once, if you stay supercharged you can do smaller stuff more often. But if I had it to do over again I would probably opt for turbo right outta the gate. If you go turbo your gonna need about $6k before you touch the car. 3k trans cause yours will blow very shortly after you get a turbo so might as well do it at the same time, then 3k for a good used turbo setup.
